Question about John Deere &Reg Branded 27" Tractor Metal Thermometer
Model 870 will not start. A new battery has been installed and there is power to the lights but noting appears to get to the starter .
    Scholar:
  • 150 Answers
Check your starter solenoid. Find it by following the pos. battery cable back to it, using jumper cable jump acrossed to other big cable on the other side of solenoid. With key in on position it should run. If it does eigther solenoid is bad, or ign swithc or the connections are dirty.
Posted on Oct 02, 2010
Testimonial: "Worked the solution and the tractor started. Solved the problem and found the pto shift was still in working mode.started by disengaging PTO."
Installing new starter
use a test light to check for power on battery cable at starter and then power to smaller wire while someone holding in key in crank position. If you have power to both your new starter needs to be warrantied/replaced
Mar 11, 2014 | 1994 Buick LeSabre
DODGE CARAVAN 2007 AND CODE PO480 + PO562 + PO700 AND FAN COOLING REST OPEN WHEN THE KEYS NOT IN CONTACT THANKS
I just had the same codes a week ago. P0562 & p0700. Found that they were both related to a battery with a dead cell. The p0562 (low voltage code caused by no good battery) causes the transmission control module (p0700) to not receive the correct voltage and act up when drawing power from the battery due to dashboard, starter, etc. drawing from battery as well, With the keys in the ignition. I changed the battery to a new one. Removing the battery will reset the codes and with the new battery the codes may not re-appear, provided there are no other codes pending that could be causing the p0700 code. Some conditions you may experience are 1) no start 2) clicking from the tcm 3) clicking from the starter 4) the dashboard lighting having a life of its own coming on and off, dimming, etc. note: when this happened to me (all of the above) I tested the battery and it was ok, but the problem existed until the New battery was installed. Still runs good now
Nov 28, 2010 | 2006 Dodge Caravan
1990 stanza car can be pushed and clutch start car.When you turn key on dash lights come on cae will not turn over. put in new battery did not help
Do you get a fairly loud 'click' when you turn the key to 'start'? If so, you need a meter or test light to check if power appears at the starter terminal when the solenoid clicks. If power appears, the starter requires repair or replacement (usually the brushes). If no power appears, then replace the starter solenoid. Hope this helps!
Nov 15, 2010 | 1990 Nissan Stanza
Why won't my '98 Chevy Malibu start, it just clicks??? YET, it HAS POWER!? I have a '98 Chevy Malibu. We turned it off after driving for about 5 minutes that day, came back 5 minutes later and it acted...
You know the 97 to 04 Malibu is noted for intake manifold leaking antifreeze into the engine. A little antifreeze in a cylinder can keep the piston from moving in compression stroke. Take a look at the spark plugs, see if any of them have antifreeze on them and maybe the starter will spin the crank with the plugs out.
Sep 13, 2010 | 1998 Chevrolet Malibu
Just installed a new battery and I have no power,
hi...
1.As you changed the battery and the volts are fine the problem lies with the wires connecting the starting motor.there may some cut in the wire which prevents the power goin to the started motor.
2.please check the fuse for the starter motor which might have blownout.
3.there may be some junction box/relay through which the power goes to the starter motor. this might have burnt out or damaged so please chekc this also
4.check the terminals connecting the battery and the motor also,
if my answer was usefull to you please rate me
Jul 14, 2010 | 2005 Harley Davidson XL 1200 C Sportster...
My car will not start and I bought a brand new battery today and installed it. However the car still will not even fire up at all, but the power in the car still works. What could cause this?
Sounds to me like you need the starter tested or replaced,if you are not getting even a click then the starter needs a set of brushes,if all you get is a click then you need a starter solenoid,either way the starter needs to come off.
Feb 02, 2010 | 1995 Chevrolet Lumina
The coleman rechargable blender not blending
Subject: Rechargeable Portable Blender Model No. 850-870
I was given one of these blenders for Christmas. I charged it through 3
cycles, used it once and the battery was dead. Charged it through another 5
charge cycles and used it once only to then have another dead battery. I
have put it through at least another 8 charge cycles, and it indicates a
DEAD battery. I have managed to blend two (2) 3/4 full pitchers in total. On
trying to start it now the green light 'flickers' quickly on and shuts down.
This is a totally useless device.
I would like to return it for a full refund, including shipping.
Dec 21, 2009 | Coleman 850-870 Single-Speed Blender
My 2000 gmc truck will not start. New starter,
I assume that you mean that the starter will not run. Do you hear the starter solenoid operate (click) when attempting to start? If so, using either a voltmeter or test light, look for 12 volt power at the battery side of the solenoid. If none or it disappears when the starter attempt is made, check the cables from the battery for badly corroded ends. Also, check the grounding cable running from the frame/body over to the engine block for damage. If you hear no click from the solenoid, look for power which should appear at the small terminal of the solenoid when starting. If you get power, replace the solenoid. If no power, then look for a blown fuse, bad relay, bad ignition switch, or any damaged wiring. Make sure the new battery is fully charged. Hope some of this helps!
Dec 14, 2009 | 2000 GMC Sierra
John Deere &Reg Branded 27" Tractor Metal Thermometer Logo
256 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
