Question about Sony Audio Players & Recorders
Hi my name is Edwin Gonzalez Ihave a Sony model #STR-695 .Recently the screen flashes (protect) I dont have the reset manuel . to see if it needs reprograming. I CHECK ALL THE POWER AMPS . AND THY ALL READ OK .Please tell me if theres any other circut I need to check thanks in advance .Edwin.
5 Suggested Answers
SOURCE: Sony STR DB-930 Receiver jumping into protector mode
I went through the amp/receiver and used small star washers on all the grounding screws I could find including the one securing the transformer, cleaned dust off all circuit boards, checked output transistors and fuses, all OK.
Re Assembled unit and it worked OK.
I will buy a fan and fan it to avoid sourcing heatsinks for the previusly suggested IC's.
Thanks for the technical help, sure solved my problem.
Regards
Darryl.
Posted on Mar 13, 2008
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
  • 167 Answers
SOURCE: Sony STR-D715 Protect Mode
This is a common problem...
It is in fact a bad power-amp module.
I have repaired quite a few of these receivers by replacing it.
The module is inexpensive. I Googled the Part number and found several sources for it.
Posted on Oct 10, 2009
  • 118 Answers
SOURCE: my sony STR-DE695 flashes protect with nothing
if it is in protection mode with no speakers connected, then youve got an internal problem which will need repaired
Posted on Feb 23, 2010
Sony STR-DB 930. Intermitent sound quality from front speakers ( low then loud ) with sharp clicking noises like relay switches clicking on and off. Thanks Dave.
I have had this problem which then developed into the unit going into PROTECT mode. This is typically caused by the relays and perhaps some other components developing dry joints over time. I had a professional refresh the solder joints and it works perfectly now
Mar 25, 2011 | Sony STR-DB930 Receiver
Sony STR-D460Z receiver
A common cause are failures in the amplifier output stage, the drivers, and some of the support components. You will have to send the unit out for service.
Jerry G.
Feb 08, 2009 | Sony Audio Players & Recorders
"Protect" Flashing
In all likelyhood, one or more output transistors have failed. Please confirm your model as STR-DE335 and I'll post the probable parts that need to be checked.
Dan
Jan 22, 2009 | Sony STR-DE335 Receiver
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Nov 28, 2008 | Sony STR-D665 Receiver
My reciever does not work
Power Amp IC gone in your set, replace it.
Jul 30, 2008 | Sony STR-DE575 Receiver
Regards
Darryl.
Mar 07, 2008 | Sony STR-DB930 Receiver
No custom names
YOU HAVE TO SAVE THEM.IF THAT DONT WORK RESET THE RECIVER BY HOLDING THE POWER BUTTON FOR 5 SECONDS UNTIL IT SHUT OFF.
Dec 08, 2006 | Sony STR-DE598 Receiver
77 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
