Question about Arcade Ms Pac Man / Galaga Cocktail Table Video Game
I have a ballys mr &ms pacman pinball machine and the sound works sparaticly , will come on random and work fine for 5 mins or so then just cuts out for 10 to 20 min nothing i do will make it come back on \r\nim just new to the pinball world so pls try not to confuse me to much ,thx
I have a eralier 80's upright Bally's Pac Man arcade machine that I got off a freind of mine. They said that they palyed it all the time up to about a year ago. I got it home set it up and pluged it in... and nothing happens. I've hit the start buttom on the inside and the new game button but still nothing... Is there something else that I may need to check?
Posted on Feb 06, 2011
My whitewater pin keeps on blowing fuse F114. display read check fuses F114/F115. Changed 114 but keeps on blowing.
Pinball problems are commonly discussed on pinball forums. For your case go to http://pinballbash.com/forum/index.php?topic=2526.msg23570#msg23570 and look for a very long append from VisitorQ. He gives a nice detailed description of the possible causes.
Aug 22, 2016 | Game Room Guys Flipper Opto Board Williams...
My mr and mrs pacman pinball machainght flipper not working what should I look for?
Bally uses an end of stroke blade switch for their flippers. Lift up the playfield and look for the blade switch associated with the right flipper. If there is a wire off or they are broken then resolder it or change them and it will be fixed. If you don't see any problem then put a jumper across the connection and see if it works. DO NOT LEAVE IT ATTACHED. If it worked then change the blade switch. Other possibilities are a bad solder connection on the Solenoid driver board or a bad flipper coil itself. Hope this helps
Dec 07, 2015 | Video Game Consoles & Games
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
All balls shot out
I need to know what machine are you working on? Different era machines have different answers.
Feb 08, 2014 | Bally/Midway/Williams Video Game Consoles...
Im looking for a 1978 bally's fireball manual
Bally made Fireball in 1972 and 1976
They made Fireball II in 1981 and
Fireball Classic in 1986
some of the manuals can be downloaded for free
from the net just search IPDB on the web
Aug 10, 2013 | Video Game Consoles & Games
My pinball machine has lights but no sound. What should i do?
I would start by pulling the cord out of the socket for a few seconds before replacing it. Sometimes pinball machines need a little reset and that should do the trick.
Jan 30, 2013 | Video Game Consoles & Games
Ms Pacman/Galaga Cocktail Arcade//side 2 not working
1.Check the dip switches for cocktail set up/ no upright.
2.does the screen flip to the player 2? if yes
3.make sure you have good dc ground in player 2 joystick.
4.if no picture flip for player 2, go to solution 1.
Thank You.
Jun 15, 2010 | Namco Ms. Pacman Galaga Cocktail Video...
Bally coin slot machine wont let the handle pull
THIS IS DOCTOR FIX. MY BUSINESS IS GAMING REPAIR. (JUKE BOX=PINBALL= SLOT MACHINES
BOWLING =POKER, FOR 68 YEARS.) IF YOU HAVE NOT SOLVED YOU PROBLEM, I ASSUME IT IS ELECTRONIC, NOT MECHANICAL. IF MECHANICAL , LET ME KNOW, I WILL TELL YOU WHAT TO DO.
ON THE ELECTRONIC, OR ELECTRIC (NO COMPUTER)
THERE IS A BAR MOVES ON TO THE CAM ON TOP OF THE CATCH, ABOUT 3 INCHES ABOVE THE BOLT THAT HOLDS THE ARM IN PLACE, WHEN A COIN IS INSERTED INTO THE COIN SHOOT, THAT METAL BAR ENGAGES THE RATCHET , TO SPIN THE WHEELS. DOES THAT HAPPEN ON YOUR SLOT.? OPEN THE DOOR PULL THE WHITE SWITCH THAT CLOSE WHEN DOOR IS CLOSED (OUT) THESE ARE A THREE POSITION SWITCH.
IN-HOME JUKE BOX REPAIR
SEYLEVITT@JUNO.COM
HOPE IT HELPS.
May 03, 2009 | Bally Walk In 9 8"" X 19 3"" X 7 6"" high...
Arcade Ms Pac Man / Galaga Cocktail Table Video  Game Logo
242 people viewed this question
Top Arcade Toys Experts
jasbo
jasbo
ray gallant
kenneth j barron
kenneth j barron
Are you an Arcade Toy Expert? Answer questions, earn points and help others
