Question about Gardner Bender #GDT-200A 7 Func Digital Multitester
How to check life of a 12v. battery? - Gardner Bender #GDT-200A 7 Func Digital Multitester
Take it to AutoZone and they will test the battery for free
Posted on Feb 29, 2012
Co detector keeps beeping
Hi. Check your battery charge level. Some co detectors are designed to alert you to low battery levels. Do you have it hooked to the house bank or does it have it's own battery? Sometime the unit itself is defective.
Aug 04, 2013 | KZ 2013 Spree Escape E196S
Needles on dash guages (temp,fuel,speed) chatter or vibrate on their lower limit pins when the ignition switch is turned on or the engine is started. After about 30 seconds the needles move to their normal...
Disconnecting the leads from the solenoid,avtivating the switch, and reading 12V is normal because you are not reading anything but the signal applied to the solenoid.You need to attach the leads and THEN activate the switch and read the voltage across the terminals.12V would mean the solenoid is good because a voltage reading is a DIFFERENCE of electrical potential.If you have the leads attached and read 0V,there is no difference of electrical potential meaning there is actually 12V on both sides and the solenoid is not absorbing/using the power like it should be.If you simply read the 2 terminals on your battery it would read 12V,likely higher because a good battery will usually read close to 13V.A bad battery may read as high as 11.8V.As for the guages,it may also be that the battery is low if it has never been changed.The average life of an alkaline car battery is about 6 years.If yours was made and sold in 2000 like they like to do these days,the battery may have been changed once and is starting to be borderline.With the car off,no keys,nothing,read across your battery terminals and please let me know what you find. gmccarthy 86 hotmail
Greg
Feb 22, 2011 | 2001 Kia Optima
I have not been able to find a store who handles the vec 142 in our area I have questions like battery battery life and how much are replacement batteries if available what is life of bulbs and how are...
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Nov 01, 2010 | Vector VEC 142 Rechargeable High Intensity...
My battery has discharged. I bought a new charger, but it seems to not carge the battery. Any actions or is a new battery needed?
I took my totally discharged batteries into an auto supply store and they left them on their charger overnight. There was no cost for that service and the batteries came back to life and have lasted an additional 6 months. I just replaced them with 12V 15Ah batteries and am getting much better performance now. The total cost for the new batteries was about $70, including delivery.
Aug 12, 2010 | Pride Go Chair Travel Power Chair
The baterry dies in 10 minutes.the motorcycle has only 6700km.should i change baterry?so soon?
Yes the battery can die in as little as 12 months if it is not used often, vibration and rough roads can also shorten battery life.
Check it has water in it up to the lines.
Put a multimeter across the battery should be just over 12v with engine stopped, rise to 13-14v with engine running to check charging circuit. Riding when the battery completely dies can overload the charging circuit.
May 14, 2010 | 2008 Yamaha XT 660 Z Tenere
The unit will not power up. first i tried the logo came on then disapperared and that won't even come on now
It sounds like the battery is dead. Check to see that you are getting 12v at the charge cord. The internal battery is a short life battery(2 hr max) and it will power up and shut off if the battery is dead and not getting charged.
Dec 18, 2009 | Garmin nuvi 200W GPS Receiver
My garmin does not operate plugged in to my car nor by battery
You have not said why that is....
Have you fully charged the battery prior to using in the car?
Using the power from the 12v plug in a vehicle will not "charge" the internal battery, but tends to maintain it somewhat. If the fuse in the end of the 12v connector plug is blown and the battery in the unit is low then this will cause the unit to shut down or fail to fire up.
Please check both, the units battery level and the fuse in the cig lighter plug and the plug that connects the unit to the cig lighter outlet.
Now the second half of your statement:
Nor by my battery
It is either not charged ( AC charger) or it has reached the end of its life which if used correctly is about 2 years. If the life of battery is shortened , then it is by a common practice of misuse. This misuse is to have the unit plugged to the car 12v when staring the engine.
1) it damages the battery life
2) It can and does damage the SIIRF chip, which is responsible for connecting to the satellites
I suggest that if it does not charge over a 10 hours Max period to its full state, then replace the battery immediately to avoid damage to the electronics from battery leak.
Thanks for using FIXYA
Oct 29, 2009 | Garmin nuvi 205W GPS Receiver
1986 will not start with new battery
sounds like a defective starter drive.
Sep 08, 2009 | Cars & Trucks
12v drill/driver not holding charge
sounds like the batt as had its the same prob as i had with mine to give it a bit of life so it will charge get hold of a bigger batt and two bits of wire and connect the + to + and - to - and it should charge but it prob will run down quick
Mar 15, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Holding battery charge on 12v DeWalt batteries
Are batteries for the dewalt cordless drill interchangeable? Will an 18 volt battery fit in a 12 volt drill?
Aug 27, 2008 | Dewalt 12V XRP Battery Pack
Gardner Bender #GDT-200A 7 Func Digital Multitester Logo
109 people viewed this question
Top Gardner Bender Measuring Tools & Sensors Experts
Vuk B
adesilva_199
Level 1 Expert
Are you a Gardner Bender Measuring Tool and Sensor Expert? Answer questions, earn points and help others
