Question about Kenmore 62602 Electric Dryer
High Heat but does not dry
Kenmore model #110-C65492400
My dryer gets very hot but does not dry. I have verified and cleaned the entire duct system as well as vacuumed down the vent and inside the back and this did not help.
Check the exhaust tube that goes out the back of the dryer. It may be clogged with lint. Ours did this about a month ago and and a thurough cleaning did wonders. I bought a kit from Lowe's with all kinds of attachments. It was really easy.
Posted on May 30, 2008
DRYER NOT DRYING CLOTHES ALL THE WAY FILTER IS CLEAN AND CLEANED OUT THE LINT TRAP AND COVER. NO CODE GIVEN. HAVE TO RUN TWO CYCLES.
Clean the exhaust duct. The ENTIRE duct, from where it attaches to the dryer to where it exits the house... Failure to dry clothing when you have heat is an air-flow issue
Jun 05, 2016 | Electrolux EIED55H Dryer
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
My Kenmore dryer does not get hot enough to dry a load
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the door opening) and let me know. I hope you find this information helpful.
May 31, 2010 | Kenmore 62802 Electric Dryer
Kenmore dryer 110-66652501 runs but does not
did you clean out the duct that the lint filter slides into?you still have a block somewhere and sounds like you popped the thermal fuse part 3392519,unplug dryer take off vent line and remove the back panel,take out the 2screws on top of dryer and remove lint filter,on left side remove the 4 screws and remove the duct,clean it out,to the right of it and around 4 inches up from floor you'll see the white thermal fuse,read it out with a meter,also if you have a long vent line from the wall to the outside blow it out with a leaf blower and make sure the outside flapper is blowing fully open
Dec 13, 2009 | Kenmore 63942 Dryer
I have a kenmore dryer model #110-74212200 and it does not get hot?
need to check vent system. restricted air flow
will reduce the amount of heat unit will give in result dry time will be extended. if no heat is detected then the thermal fuse needs to be replaced. thermal fuse blows when there is not enough air flow over heating element. meaning there is a restriction in the venting system.
Jun 21, 2009 | Dryers
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
FRIDGIDAIRE GAS DRYER MODEL # GLGR642AS2 IS NOT DRYING CLOTHES BUT GAS IS IGNITING. THANK YOU. DON
Hi Don,
So let me get this straight, you are getting heat from the gas burner and the drum rotates but your clothes remain wet? You can check a few basic things to identify where the problem lies.. First off, have you checked the lint trap and cleaned it? Secondly, have you checked your vent system ( meaning : are you sure it is not clogged anywhere in the duct or at the end where it exits outside? If that's OK.. when your system is drying clothes.. do you get hot air flow at the end of that duct? If not, your blower may not be working ..You need to move that hot air out of the tub for the system to dry. Heat, Motion to move clothes, air flow from the blower and an unimpeded path via the vent duct to outside.. Hope one of these things to check gets you going. Regards...
Sep 03, 2008 | Dryers
Very high heat and timer won't advance
Stop !!! You are creating a much larger problem by trying to fix this at this point.To correct the problems it has now is not going to be practical to cost.My advise is to push this aside before you have a disaster.Buy a new /used dryer that is working and when it does need a repair you let me know,do not try to repair anything your not sure of because it makes it impossible to correct the added problems at a low cost.
Apr 19, 2008 | Kenmore 62602 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Kenmore 62602 Electric Dryer Logo
108 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
