Question about JVC Televison & Video
I have a JVC AV-48WP30. I replaced the IC's Popping noise went away, can only turn set on manually, set does not respond fully to commands from remote can not adjust convergence.
  • 13 more comments
  • Mike Schmidt
    Mike Schmidt Oct 04, 2010
    Hi There - thanks for the quick response. When I replaced the convergence ICs I checked those resistors, no heat discoloration and measured with ohm meter and values are unchanged from your description. I wonder can the microprocessor chip eprom loose its programing? If so where would I download drivers?
    Mike
  • Mike Schmidt
    Mike Schmidt Oct 05, 2010
    Initially I can turn set on with ON/Off control on control panel. Pressing MENU button on control panel screen changes to service menu. Pressing MENU button advances to next item, CHANNEL button on Control Panel selects item. Pressing MENU returns to previous screen. The only time that the remote has any effect is when the EXIT button is pressed, exiting MENU and returning to video - Mike
  • Mike Schmidt
    I do have service manual. Can only pull up convergence pattern from manual selection on the Front Control Panel of the set. The set responds to the EXIT button only from the remote control. Is there a procedure to restore the set to factory presets?
  • Mike Schmidt
    Mike Schmidt Oct 07, 2010
    I have changed out the Convergence Chips on the JVC, checked the resistors all ok no burns resistances ok, only able to turn on tv from front panel on set, advance thru menu with MENU button on set, only function that works on remote is EXIT button, is the programming of the set corrupted, if so how is TV reset to factory presets?
  • Mike Schmidt
    Hi Tim
    Thanks for the quick resopnse. One of my earlier thoughts (not posted) was the IR receiver module. I have purchased IRs for the module board. The original configuration has only 1 IR receiver on the board though the board has the capability for 2 and the loom is set up to accept 2. Only thing to do to the board to accomodate 2 is to add the second IR receiver and a 1K resistor. To say the least this has really had me scratching my head.
    Mike
  • Mike Schmidt
    Hi Tim - In a few moments I am going to replace the original IR receiver to get it to a functioning state then, add the second IR. It seems odd to me that JVC would have the wiring in place but only use a board with half the capability. - MIke
  • Mike Schmidt
    Hi Tim - I replaced the I/R receiver and no improvement. To recap, convergence ICs were changed - cleared popping problem, video appears, diagonal lines from upper right to lower left, picture really bright and washed out, pressing front control panel MENU button, menu appears, pressing MENU button scrolls thru menu, channel < > selects item. When convergence is is selected and screen changes to the alignment crosses then and only then does the set respond to the remote and then only the EXIT button. Any other ideas?
  • Mike Schmidt
    Hi Tim - I tried to go into Self-Test Mode, on front panel, Press Volume down button and press ON/OFF button will not display, raster is present, Input displays (Input 4) in upper right corner in this case I have my laptop plugged in the front panel screen is washed out just bright redish light. When I press Service button in front of set I do get cross-hatch grid and dashed cross-hatching alternating between red and green. - Mike
  • Mike Schmidt
    Mike Schmidt Oct 08, 2010
    Did you send a msg? My email indicated you did, if you did nothing came thru. - Mike
  • Mike Schmidt
    I have been working on the off and on for a year. I researched my notes from a year ago. Have you heard of problems with production crayon marks on back side of boards causing shorts? The other thing I can posible see is the IC2 Memory Chip for the CPU lost its programming. Can a replacement be ordered or firmware reloaded to it?
    Mike
  • Mike Schmidt
    Can this chip have memory reloaded? If not does JVC still sell replacements?
  • Mike Schmidt
    I did an online check with The Parts Store and found the part MM1437AF-X for $20.95, JVC P/N is IC 703/IC1703 AT24C32 for $45.57. In either case I do not know if the chip comes pre-programmed. If not pre-programmed I am sunk as in order to get into the Service Mode, you must press the Sleep Timmer button and while the "0" is displayed press the Display
  • Mike Schmidt
    cont: and the VSTATUS button. Since the set responds only to the EXIT button well, it may not be repairable and off to the landfill. So far my investment has been my time and $30 in parts.
  • Mike Schmidt
    Hi Tim - I was able to get the Technician Screen to appear (hold -Volume button, then press ON/OFF then release) the display came up and verified MEM NG. This looks like I might have to purchase it from JVC. I can purchase this chip locally for about $8 but it is diffinately unprogrammed. I know most folks would have tossed this set by now. I have a mind set that I should be able to sign my name to a project, even if it is for me. My need for this set is to have a very large monitor for my computer. I also have an Advent Videobeam 1000A I reapaired it is a 1978 model. I will pay you for your time. Thanks again for your help. Here is my email address if you want to contact me. Foxtrot7051@yahoo.com - Mike
  • Mike Schmidt
    I took a little bit of back and forth as the problem finally narrowed to the memory chip IC703, after getting a manual Tech Screen display the Self Tests verified MEM NG. When this happens the set wil not respond to most all buttons of the REMOTE CONTROL.
    President:
  • 2,777 Answers
Hmmm very strange, does it respond to the remote at all? Sounds like somehow the I/R receiver stopped working at the same time or was disconnected. Looks like you've been around a few days here, have you made any progress?
Thanks
Tim
Posted on Oct 07, 2010
  • 7 more comments
  • Tim Grayson
    Tim Grayson Oct 07, 2010
    I missed the question there.. it sounds like you have it handled? You are adding a second I/R receiver and the resister then correct? Or just replace the one i/r receiver and at least get it back to fully functioning...
    Tim
  • Tim Grayson
    They do things like that more than you can imagine. The company just mass produces the boards for them and they use the same boards in many model TVs, some using 2 i/r receivers, some using just one... They say a few pennies by leaving off that second IR on many models but use the same board because it's more expensive to have another board made...
    Anyway, hope that module gets you back up and running!
    Tim
  • Tim Grayson
    Wow that is a wild one.. but before was the remote responding at all? If that exit button was working before I definitely missed that part, that would have confirmed that the i/r module was working.. I read through all the comments I could see from before I got involved and didn't see that mentioned..
    I am conferring with a few people here to see what we can come up with for what could be going on here.
    Thanks
    Tim
  • Tim Grayson
    People here are thinking it's the main board of the TV and that is my suspicion as well. Still researching though, what are you thoughts on the mainboard?
    Tim
  • Tim Grayson
    Tim Grayson Oct 08, 2010
    Yes you may need to click the view more messages button to see them.... I have replied for sure..
    Tim
  • Tim Grayson
    A replacement for that IC 2 memory unit for the CPU? Yikes, that will be hard to find but it's possible....
    Tim
  • Tim Grayson
    Unfortunately I think the answer to both is no, but checking now to confirm.
    Tim
  • Tim Grayson
    I saw that chip at partstore.com as well, but am quite sure it isn't pre-programmed. I think you may be right in that you want to just replace at this point... I'd be going crazy over there if it were me...
    Tim
  • Tim Grayson
    Ok sounds good lol, wow you are quite the repairman for sure! If possible please come back to the question here and click the Accept
    This Solution button, otherwise I don't get credit for the help
    provided.
    Thank you so much,
    Tim
    Also you can email me at microtechftp@yahoo.com
  • JVC Master
  • 5,138 Answers
After you replaced ICs,did you Check these resistors R846 (1.5 ohms) R850 (2.2) ohms R854 1.5ohms R862 1.8ohms
Posted on Oct 04, 2010
  • 1 more comment
  • ladywinn
    ladywinn Oct 04, 2010
    I think their is 3 different ways to Enter Service Menu in order to Adjust Convergence
    With Remote Control PRESS: Display
  • ladywinn
    For some reason page did not print everything I typed out?
    PRESS Display and Video Status at same time to Enter Service Menu
    Press Menu Up/down to adjust up and down PressMenu left and right to adjust forward and backwards Press Exit twice to leave Srrvice Menu.
  • ladywinn
    ladywinn Oct 05, 2010
    You are suppose to be able to adjust with Remote Control Hand Unit.
    Go to Retrevo.com They might have Service Mannual and Owners Mannal.
    Are you not able to adjust Convergence ? Does Covergence Pattern come up?
Tv suddenly will not turn on i am getting rythmic popping soung through the speakers?
picturetube has went out, or is going out. try to unplug it for a while ( a few hours or even a day or so) if the picture comes back on thats great but then you know its not out but going out. it will be cheaper to just replace it.
Mar 29, 2012 | JVC AV-48WP30 48" Rear Projection...
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48wp55 Made a loud noise and went dead instantly.
WELL IF IT WAS A LOUD POP,YOU NEED TO REPLACE THE FLYBACK TRANSFORMER,GET THE MAKE AND MODEL # AND DATE OFF THE BACK OF TV, AND CALL MATS ELECTRONICS #1-800-628-1118
Feb 15, 2010 | JVC AV-48WP30 48" Rear Projection...
Makes a poping noise out of the speakers when i turn it on? can ya help plz thnks james
If you have no video and its making a popping noise its mostlikely shorted convergence circuits. Contact www.TvRepairKits.com and ask them to make you a kit for chirping sets.
May 16, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 Problem
the best place for parts with free installation instructions is the following link. In fact its the only place that I am aware of that send s instructions with their parts.
http://servicemanuals.vstore.ca/
Apr 21, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48 in. Rear... Problem
Your convergence I.C's ( integrated circuits ) Have failed. Replace Both I.C's with Stk392-150's. The unit is equipped with 110's. These are large IC's pn the convergence board located near the front of the unit. You need soldering/desoldering experience to do this job. I would recommend seeking professional assistance.
Jun 04, 2008 | JVC AV-48WP30 48" Rear Projection...
Which IC should I replace if the RED is off?
You would need the service manual to dtermine which IC controls the red. One IC controls red and the other controls blue. If the red was replaced before. It probaly went out as some suppliers dont use origional sanyo ICs. Which unfortunately dont last as long as the sanyo parts do.
Mar 13, 2008 | JVC AV-48WP30 48" Rear Projection...
1.5 days after replacing both IC chips the blue started ghosting again and then...
The biggest problem you stated yourself. You bought aftermarket type IC's. You should have been smarter and purchased the correct IC's for the set. All IC's are not alike, even with the same number on them. Aftermarket IC's are just that. Built in China or are factory rejects. You might get away with replacing the iC's again from a reliable dealer or you might have messed up the power supply in the meantime. Good Luck
Mar 02, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
168 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
