Question about Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor
This Bostitch Pancake 6 Gal. compressor was working fine. Today it refused to compress beyond 30 pounds. Last time I used it (a week ago) it zipped right up to working pressure. Now it just runs and runs. If I turn it off it holds at 30, so there doesn't seem to be a leak. The compressor appears to need something, but what?
PRESSURE REDUCER valve
Posted on Nov 02, 2010
My bostitch 6 gal compressor keeps running , and running , even goes into a higherpitch motor noise. can i check something ? or clean something to fix it ?
is it building up any pressure on the gauge
if the pressure recorded is around 40 psi or less , replace the failed poppet/reed valves in the compressor head
if it goes to 100 psi then replace the automatic controller for the motor
Jun 15, 2016 | Stanley Bostitch CAP200P-OF 6 Gallon...
My fn1664k does not shoot a 2 inch nail all the way into a 2x4
Check the pressure at the gun to make sure the hose is good. Make sure the gun is oiled. The compressed air forces a piston down to drive the nail. the inside of the cylinder may be corroded causing the piston not to move as fast as it should or with as much force. Most air guns are pretty easy to disassemble to inspect. You should be able to figure this out pretty quickly this way.
Oct 31, 2014 | Stanley Bostitch FN1664K 16 Gauge Finish...
I have a bostitch 6 gal pancake compressor that won't build pressure past about 20 lbs. when I turn it off I don't hear air leaking out anywhere and when it's running it runs at a higher pitch ( similar to...
I'd pull the cover off to expose top of cylinder head and have a look at any intake air filter. In parts diagram, It appears there is a small one that would likely clog during the texturing process.
Jan 26, 2011 | Stanley Bostitch CAP2060P 105 Amp...
I have a model cw0100 1hp 4gal. and need to know capacity of oil tank.
Check you model number. I don't think cw0100 is correct. Most 1HP 4 gal pancake compressors are oil-free.
Jan 09, 2011 | Stanley FactoryReconditioned Bostitch...
Type of oil used in pancake stanley compressor
An air compressor should have 30 weight non-detergent oil only, or it will foam up and not oil the bearings.
Sep 20, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Stanley NEW Bostitch 2 HP 6 Gallon Electric Air Compressor Logo
1,834 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
