Question about Zonet 2PORT Desktop USB To KVM Switch with audio+usb Port 2SETS Of Cables
Where can I get longer cables? like 10 feet I have
Where can I get longer cables? like 10 feet I have a kvm3332 switch
    Master:
  • 397 Answers
Generally you can try sites like Tiger, Newegg, or Compusa.
Posted on Oct 02, 2010
What is the purpose of the usb plugs on the PC1 and PC2 cables of the Zonet KVM3332
If you have external hard drives they will switch to either PC connected to the KVM
May 31, 2014 | Computers & Internet
Run for 2 feet and stop and resart 10 second later
sounds like a loose shifter switch or foot pedal switch, try lifting the rear of the vehicle and then hit the gas pedal and see if it runs longer, if it does then your switches just need to be seated better
May 11, 2014 | Peg Perego John Deere Gator HPX Ride on...
UK Broadband Fibre Optic and Ethernet
Coppper CAT cable length limit is 300 FT. Don't recall fiber at this moment, but even much longer.
Nov 22, 2012 | Sony VAIO VGN-FZ290E1 Notebook
Hitting control twice no longer switches my computers back and forth, how do I correct that?
Try unplugging the power from the kvm is powered, if not turn off both computers and unplug all connections for 30 seconds and then connect it all back and turn on both computers.
Aug 29, 2011 | Zonet KVM3332 2port KVM Switch
Pls my linksys switch SD216 looses contact with my internet and it killing my business, pls what should i do to resolve this issue thanks.
This problem may be caused by your cabling.
Here are the right distances for your Switch.
From Switch to Swich or Hub you have a maximum distance of100 meters(328 feet)
From Hub to Hub max 5 meters(16,4 feet)
From Switch or Hub to Computer max 100 meters(328 feet)
When you connect your network devices,make sure you don't exceed the maximum cabling distances.
Another problem could be the power adapter,this could be damaged;Note:using a different power adapter may result in damage to the Switch.
Nov 25, 2010 | Linksys SD216 16x10/100 Mbps Networking...
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at...
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Sep 27, 2010 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Monitor to PC Cable to get Monitor USB Ports Working
Belkin F3U133-10 Hi-Speed USB 2.0 Cable (10 Feet)
http://www.amazon.com/Belkin-Pro-Device-Cable-Feet/dp/B00004Z5M1
USB 2.0 A Male to B Male 28/24AWG Cable - 6FT
http://www.monoprice.com/products/product.asp?c_id=103&cp_id=10303&cs_id=1030301&p_id=209&seq=1&format=2
Jan 12, 2010 | Dell 1505FP 15" LCD Monitor
What type of HDMI cable do I need to connect my DVD player to my HD Sanyo TV?
Make sure DVD player and TV have HDMI ports at back to hook with HDMI cable.
HDMI cable has standard plugs on both ends and its length can be different like 3 feet, 6 feet or 10 feet. Click HERE to buy required length HDMI cable.
Oct 23, 2009 | Philips Televison & Video
USB Cable
The longer one will work, no problem.
Now if the cable was 25 or 50 foot long, that would be a completely different story.
6' is what they consider as the "ideal" length.
Oct 18, 2008 | Office Equipment & Supplies
Zonet 2PORT Desktop USB To KVM Switch with audio+usb Port 2SETS Of Cables  Logo
46 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
