Question about Frigidaire Kitchen Ranges
MODEL NUMBER FEFL89CCB. THE OVEN WILL NOT HEAT I have tried it in all modes The top works as do the clock and timer. We do get an F1 error. Are there any other options other than replacing the electronic oven controller?
fridgetech
  • 473 Answers
SOURCE: What does "F1" mean? The oven is out!
I think f1 is a problem with the oven control board. Look on the back of the oven for a tech sheet and it will tell you what the codes mean and what to check.
Posted on Oct 06, 2007
fridgetech
  • 473 Answers
SOURCE: F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Posted on Nov 07, 2007
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
Maytag317
  • 1136 Answers
SOURCE: Model # 362.7361193 When I set the oven to any
Hi, The most common problem is the oven ignitor goes bad.
Remove the floor panel in the iven and test the ignitor to se if it is getting 120V.
The ignitor can glow but still be bad.
I hope this helps. please let me kow if I can assist you further.
Vic
Posted on Jun 12, 2009
Frigidaire gas range model ES330 error code SAb
This is SB mode, show room mode. To deactivate showroom mode, remove power and reapply. Press Cancel to bypass programming clock. Within 60 seconds of reapplying power, press Oven Light key and top oven Timer key simultaneously.
Aug 05, 2012 | Kitchen Ranges
Electric oven wont heat up
Check your manual to make sure that you can re-calibrate the thermostat as long as your clock is working., the timer works, and the START button is working. If the timer can't be started, it may b3e a touchpad problem. Do you have F1 error message? If nothing is working then there might be a tripped circuit breaker.
Jul 23, 2011 | Whirlpool GBS307PD Electric Single Oven
The clock area shows an f1 error code and nothing else works on the oven
Please identify the model and part number of the control. I should be able to help you. You can also visit our website for more information on timer failure diagnostics.
Mar 17, 2011 | Kitchen Ranges
Hello hriley2214,
I just want to clarify the problem before moving forward. The oven will not heat either in bake, broil, or convection, correct ?
How about the cooktop, does it function normally ? As does the clock/timer ?
Let me know and I can try and assist you further with that info.
Thank you,
macmarkus :)
Jan 05, 2010 | Frigidaire Kitchen Ranges
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Oven turns on by itself and F1 flashes on the digital clock
Without being able to look up the error codes for your model (number please!), I would guess that the oven control triac has shorted out or the relay is stuck on (I assume the oven runs at maximum temperature). In any case, the oven microcontroller knows something is wrong, so it says F1 and beeps for help.
Aug 10, 2009 | Kenmore Kitchen Ranges
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Nov 13, 2008 | Maytag Ovens
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. Catriver..post back.
Oct 12, 2006 | Roper FGP300 Gas Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
