Question about Nikon Super Coolscan 4000 ED Film Scanner (35 mm)
My Nikon CoolScan 4000 is not working properly. All images come with a green shade
I had the same problem with coolscan LS 50 ed, but the chromatic dominant was blue instead. What you have to do is to perform a p.o.s.t. procedure: 1) swith off the scanner and unplug it from the PC; 2) switch off the PC; 3) remove the film-holder from the scanner; 4) switch on the scanner; 6) plug it back to the PC; 7) switch on the PC; 8) insert the slide/film holder. It should work now...
Posted on Oct 12, 2010
Recently upgraded from Windows Vista to Windows 7. Where can I get correct drivers to run with my Nikon Super Coolscan slide scanner LS-4000 ED model. I have Nikon Scan 3.0 twain software. Stu Milligan
Hello there.
This will help you if you have 64-bit Windows 7, because officially, there is not windows 7 64 bit driver.
Just read and do everything.
http://www.earthboundlight.com/phototips/coolscan-vista-64.html
Otherwise, if you have windows 7 32bit click here:
link
To check bits, go right click on My Computer, Properties, and you will see it.
Sincerely,
Steve TM
May 28, 2011 | Nikon Super Coolscan 4000 ED Film Scanner...
Need a new driver for coolscan 4000 ED for Vista.
You can download the Vista Driver at this link: 4.0.3 full version - Vista only
If this information was helpful, please give me a big thumbs up when you rate my answer.
Feb 03, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Where can I find the Nikon CoolScan 4000 Scanner Installer?
Please follow the below link and download the installer for your CoolScan 4000
http://support.nikontech.com/app/answers/detail/a_id/16453/session/L3NpZC9pODRBbzJNag%3D%3D/p/25%2C27/c/185/r_id/116678/sno/1
Click on "I agree - begin download" and the download will start.
Install it and enjoy.
Cheers
Nov 03, 2009 | Nikon Coolscan IV ED Film Scanner
I believe my coolscan 4000 may have or is failing - can you help me determine if it is a hardware or software (driver) problem?
I contacted Nikon Tech Support and with them determined that the scanner failed POST and needed hardware repair.
Oct 06, 2009 | Nikon Super Coolscan 4000 ED Film Scanner...
Trouble ejecting slide from SF200 nikon coolscan 4000 ed
open the case of the scanner, and check to make sure that the ejection mechanism is not malfunctioning, or jammed someway.  If this is not the problem, try using thinner slides as thicker ones could also cause this.  If all else fails try un plugging the scanner for a few minutes, and try again.
Jan 10, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
USB cable from scanner to new Dell Optiplex 755
If you look carefully at the cable, you will notice it is a firewire cable (IEEE1394), not USB. You will need a firewire interface on your computer to use the Nikon scanner. It will not work with a USB port.
Jan 02, 2008 | Nikon Super Coolscan 4000 ED Film Scanner...
Coolscan 4000
Well, I finally discovered the solution to my problem of not being able to scan...the scanner had several broken parts inside including pieces of plastic wheels and such as well as a spring jammed in the upper slide rail. So, it was not able to re-set or move into the proper position to begin a scan. I called the Nikon repair facility in Las Angles and they wanted $200 to check it out plus parts to fix it. So, instead, I purchased a Coolscan V and it works great! I still have the broken Coolscan IV and may try and have it fixed someday.
Nov 06, 2007 | Nikon Coolscan IV ED Film Scanner
Nikon Super Coolscan 4000 ED Film Scanner (35 mm) Logo
713 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
