Question about Maytag Washing Machines
My Maytag commercial washer has the unbalanced light on and wont operate. How do I get the light off and it to operate. Have already repositioned the load and moved the bowl around. Thanks Steve.
MNfisherman
  • 11896 Answers
SOURCE: Maytag Bravos washer leaks.
Either the valves are leaking themselves or tub is leaking. Most likely the water valves.
Posted on Oct 24, 2009
ttech
  • 139 Answers
SOURCE: empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Posted on Jul 20, 2007
SOURCE: Maytag MAT12CSDAW
Try the following on a top loading washer. Prior to opening the lid, find the tiny switch that engages/disengages the water upon lid opening and closing (found on the back right corner of my model).  This is your target! Open the lid. Push the washer drum to the back to access the "real switch" underneath the lid/washer housing.   The switch can be pushed back and forward (this is how it engages/disengages water) or pulled slightly down.  Pull the switch down and close the lid. You are good to go!  Hope this helps!
Posted on Dec 01, 2008
aborcass
  • 2651 Answers
SOURCE: Torn bellow on Maytag front load washer
there is a spring style clamp holding it to the front panel simply peel back slightly and "pop" it off, then holding it to the inner tub is a screw style clamp, depending on yr of production, either a 5/32 scrwe or a phillips, holding it in the 2 oclock position, release clamp andreinstall boot, it might take some time to get to fit backaround hte tub but itll bo, you gotta walk it on in spots ( like changing a tireon the bikes as a kid) itlll strectch over the rim and fit, just have to work it
Posted on Dec 03, 2008
landsend
  • 1066 Answers
SOURCE: maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Posted on Mar 11, 2009
My washer wont drain , the door locks and the sensing estimated time lights wont come on?
shiela,you have a blocked pump or a bad pump,i wrote to you already on how to clean out the pump and you'll be fine.
Apr 16, 2013 | Maytag MHWZ400T Front Load Washer
Hotpoint top load unbalanced
Darla heavy objects such as towels and jeans not evenly distributed in the washer will cause this to occur, open lid let washer come to a stop and then reposition clothes
If it is unbalanced as in the whole machine rocks even when not running then the rear levelers are out of position, pull top of washer towards you tilting the whole machine, towards you, the rear levelers will self adjust unless jammed, you may need help tilting the unit
Jul 09, 2012 | Hotpoint VVSR1070D Top Load Washer
I have a maytag washer i bought in 97. It became unbalanced well my husband fixed it and everytime it goes on the spin cycle it gets unbalanced again and makes a very loud noise
If the washer is truly balances (check with a level to be sure) you might just have an unbalanced load. When filling your machine with laundry, think of the tank as a big circle divided into four pie slices. Make sure you fill each of the four slices evenly. This should help,
Nov 04, 2010 | Maytag Washing Machines
Unbalanced maytag
probably the inetia switch on the top of the tub
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition...
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont drain and spin
65mungus
You have clutch malfunction. Take a look at my Clutch Fix post and see if you can DIY the fix.
Basic hand tools and DIY skill sets is all that is required and you can save your $1K machine. Post back if you have questions or concerns…..Rich
Mar 28, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer tub leans to the right
I have a Mayag Washer and dryer The washer someimes spins of balance. the dryer has no heat, this just started. would it be the element?
Oct 23, 2009 | Maytag Performa PAV2200
Maytag coin-op top load wont spin, motor runs, belt burns.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
Empty washing machine still unbalanced
Jul 20, 2007 | Maytag MAT12CS Top Load Washer
Washing Machines Logo
1,507 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
