Question about Sentry Fireproof Safe
I have a electronic SENTRY S3871 and changed the original combination, but the battery is dead now and I can`t find the original numbers . If I replace the battery the safe works with the new combination?. If not, how can I get the original combination? The safe is open. Thanks.
  • 9 Answers
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Posted on Feb 08, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
SOURCE: sentry safe S3877 have key and know combination but battery dead
Our safe had a philips screw at the bottom of the keypad (facing downward), not a paperclip hole as some do. To replace batteries, unscrew this setscrew and twist the face gently. Replace the 4AAs and reinstall faceplate/fingerpad. Should work.
Posted on Sep 04, 2010
SOURCE: The battery on my DSW3607
the battery pack is in the front where the combination is located. take off the front part, there is a screw at the bottom, batteries are behind.
Posted on Dec 10, 2010
I have a sentry s3871 safe. i would like to change combination number.any ideas!
Hello Julie,
May be you should try to get in touch with them directly just to make sure
Please contact our customer service department at 1-800-828-1438 Monday-Friday 8am - 6pm EST.
Oct 16, 2014 | Home Security
How do I open a sentry s3877 safe when the battery is dead and safe is closed
The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
If you do not know your factory code, you can follow this link for your combination retrieval:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Sep 23, 2012 | Sentry Fireproof Safe
Have had a CSW 3813 Sentry Safe for several years. Have had no problems until lately. Key #2090 opens the lock, we punch in combination that we have always used, then punch enter. The response is, the...
Sounds like you need a new battery replacement.
To replace the battery pack, unscrew the screw below the electronic lock case, turn the lock case to the right then remove it.
You can have the online manual from the link below, just make sure you have installed the adobe acrobat reader on your computer to view this file cause its pdf format.
http://www.sentrysafe.com/pdfs/OwnersManuals/503662.pdf
Additional info can be found from this electronic safe sentry manual
http://www.sentrysafe.com/pdfs/OwnersManuals/505748.pdf
If the problem leads to acquiring the right combination for your safe.... call the attention of Sentry Safe Shop
You must call (800) 828-1438 for combination retrievals.
or send a notarized letter stating you are the owner of the safe, personal information, model and serial number of your safe and must indicate the method on how you will receive the combination.
See further details from this link
Please post back for any clarifications and let me know so I can help you further.
Apr 05, 2011 | Sentry Fireproof Safe
We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
Dec 07, 2010 | Sentry Fireproof Safe
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
Sentry safe v260 . have both keys but forgot the combination. how can i over write it?
If you have a "3 number combination" or have a "4 number combination you that you have NOT changed", you can send in your serial number in a notarized letter and $8 to: Sentry Group, Dept 200, 882 Linden Ave., Rochester, NY 14625-2784. (this info is in your Owners Manual under Lost Keys or Combination) If you don't have your Owners Manual you can download it from: http://www.sentrysafe.com/products/productDetail.aspx?s=130
If you have a "4 number combination" and you HAVE changed it from the original cobmination, the only solution you have is a locksmith.
Jun 13, 2009 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Jan 04, 2009 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
312 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
 Brian Main
Brian Main
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
