Question about Insignia 42" LCD Flat-Panel HDTV
Insignia ns-lcd42hd. Red power light comes on when initially plugged in. After power button is pressed, light blinks once from red to blue,shuts off for a half a second, then back to blue, and stays that way, yet no picture. Once the unit is on, if you press the power button, I get 15 red blinks, then steady red light. Opened the unit, found no bad fuses Left it plugged in, and while removing the bigger harness off the left inverter board, the backlight came on. If the harness is partially connected, about half of it, the backlight comes on, but still no picture. What could this be? Is it in the inverter board? I dont beleive its the power supply, due to the backlight coming on. Is there some sort of microrelay in the power supply, or are they in the inverter boards? ANY help please!!
  • 2336 Answers
SOURCE: Insignia NS-32LCD Backlight or Inverter bad???
If you've done the flash light test, it could be the inverter board became defective but it could also be that the power supply does not provide the +24VDC to the back light inverter board.
If you could do the +24VDC test using a voltmeter then we can say for sure that the back light inverter board is defective.
Let me know if you need further assistance.
Posted on Aug 21, 2008
  • 61 Answers
SOURCE: insignia ns-lcd32
Bubulica2000,
There is two reasons to have no display on your screen.
1.LCD panel itself is deffective.
2.Main board(mother board is Deffective)
How to recoganize the problem?
There is 5VDC going from main board to LCD invertor ( different model different pin so I am not able to tell which pin or Jack is)
Check while unit is ON mode it should read in between 3VDC to 5 VDC.If this volt is correct your LCD panel is Deffective.If no voltage appear in this pin Simply change Main board(mother board)
Dont forget to rate!!
GoodLuck
Dals123
Posted on Oct 21, 2008
  • 11 Answers
You can download the manuals from the Insignia website at:
http://www.insignia-products.com/c-14-lcd-televisions.aspx
Jerry
Posted on Dec 08, 2008
SOURCE: How to remove the back from Insignia NS-32LCD?
I unscrewed all the screws in the back, detached the tv from the base, and was able to get the back off. I ordered a new power supply board and will install it to see if it fixes the problem with the tv (won't turn on, insignia light alternates between red and blue). I didn't notice any problems with "swollen" capacitors, so if the new power board fixes the problem I'll update this website.
Posted on Jan 28, 2009
BoiseLCD
  • 63 Answers
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris Boise LCD www.boiselcd.com
Posted on Apr 23, 2010
My insignia ns-lcd47hd-09 does not turn on at all.
check if there is a secondary board check out the capacitors if they look inflated the are probably blown replace the with exact uf and voltage and it should switch on
Jan 28, 2018 | Insignia Televison & Video
Insignia tv light blinking red and blue
you have a faulty parts inside..try to disconnect one by one the supply of all board until you get stable lights..
Jun 14, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Red going all through the picture
red dots or noise moving can be main signal board or power supply-is this what you are seeing?
Apr 15, 2012 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Ihave a insignia ns-lcd47hd-09 tv. when i press the power button the light turns blue but no picture comes on only black screen.
I think your insignia is set for SHOP mode instead of HOME mode. I changed mine to HOME and it's working fine now. Press your menu button and then scroll down to setup. You're looking for Plug and PLay which should be the very first choice. If it's greyed out as mine was you'll have to change your imput from HDMI to TV in order to get to the P&P. Once you're in the Plug and Play your first choice is language. The second should be SHOP or HOME. Make sure to select HOME. You can skip scanning for channels. This fixed my problem with the blue light. The store uses SHOP so if someone plays around and changes something, all they have to do is shut off the TV and turn it back on. Please let me know if this works.
Oct 03, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
Where?
power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
Too shut off hold down button 4 until red light comes on.
if want too pair with device hold button down 6 seconds until light blinks blue red
pass code is 0000
May 15, 2009 | Insignia Bluetooth Wireless Headphones...
Why does insignia ns-bthdp have a solid blue light?
I had this problem but the red light was on constantly with no response to anything I did. I plugged this into my power adapter and pressed the + and - buttongs at the same time and it reset and started working properly.
Nov 11, 2008 | Cell Phones
Insignia ns-lcd37 remoe codes
Samsung DVD player codes: 20490, 20573, 21932, 21075, 20820.
With device turned on press DVD button on insignia remote then press and hold setup until the red led light blinks twice. enter code and it should blink twice again. press power button to check if code took. If not, try another code.
Oct 29, 2007 | Televison & Video
Insignia 42" LCD Flat-Panel HDTV Logo
208 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
