Hi On a Fellowes paper shredder for home use The printed circuit board that has the on/off switch has a resistor that seems to have overheated and failed It is labelled orca 5300*02 (ac) Is there a diagram to find resistor value and power rating or a replacement board Thanks
  • felipegomez Oct 03, 2010
    Thanks
    It is not a fax machine ...it is a paper shreder. I am familiar with the color code, yet, in this case we are going to either need the diagram or a source to buy the replacement PC board because the resistor is burnt, no colors are visible
    Any other ideas?
    Felipe
  • 2,973 Answers
Felipe,
If it is a Chinese board there is not very much one do about them other than replacing the board as you are prepared for it. But before we do that lets try and decipher the resistor values. After that all you have to do is match the value and solder it to the board. Visit the following links and match the colors carefully to get the correct value.
http://www.interfacebus.com/resistor_table.html
http://www.csgnetwork.com/resistcolcalc.html
Posted on Oct 03, 2010
    President:
  • 1,514 Answers
Resistor values are defined by the colour bands on their bodies. An explanation of how to read the colours can be found at http://wiki.xtronics.com/index.php/Resistor_Codes
If you simply want the value there's a calculator at http://www.dannyg.com/examples/res2/resistor.htm
Just select the colours in the same order as they are on the resistor to find the value.
Posted on Oct 02, 2010
  • Joe Bannon Oct 03, 2010
    There is a website which offers circuit boards, and other spare parts, for paper shredders including Fellowes make at http://www.compax.com/shredders/parts.ht...
    As I don't know your model I don't know if they have your model. They do say that if it's not advertised there to get in touch with them. I hope this helps
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Fellowes 99Ci won't turn on blue light, but fuse not gone
The motor may have overheated and failed. Also, there could be an accordion folded strip of paper jamming the works. Even the best shredders for home use seem to require regular removal of accumulated paper from the shredding mechanism because they are not self cleaning.
Mar 12, 2014 | Office Equipment & Supplies
Where to oil a Fellowes Powershred 320 CC paper
I continued to search via Google until I found the manual for this shredder, which I then printed out and read how to lubricate the shredder.
Jan 26, 2010 | Fellowes Office Equipment & Supplies
Fellowes Powershred PS 60CC stopped working
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
May 16, 2009 | Fellowes 3011001 Shredder
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
May 12, 2009 | Fellowes S701CM Shredder
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Jan 08, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Trigger Switch -- Fellowes S70C-2 Paper Shredder
Unfortunately there is no longer a parts program available for this machine. It has been phased out.
Oct 03, 2007 | Office Equipment & Supplies
jasbo
jasbo
