Question about iLO 3200 32 in. LCD Television
Ilo 32 in television
We have a ilo 32 in tv can you tell me exactly how to hook up the surround sound to the TV? We tried but only can get it to go through part of the surround sound. Can you help me.
I need to hook up remote for Direct TV and Ilo is not listed as a choice what do I use?
Posted on May 29, 2008
Audio output on TV
Sounds like you have it hooked up properly. Be aware that if there is not a digitally encoded signal for surround sound [they don't always do that] you simply won't have surround sound. Usually there is a mode in your receiver/amplifier that will allow you to simulate surround sound. An example of that would be "theater" or "hall" sound. Try it with a DVD known to have surround sound encoding [most of them do] and see if it works that way. If it doesn't then check your owners manual for information about how to make sure that feature is actually turned "on".
Apr 16, 2010 | iLO Televison & Video
Trying to hook up surround sound and when i get the cables hooked up there is no sound coming out
Try go to ur tv menu got to audio setting reset to back to factory setting.Should solved this problems.
Feb 06, 2010 | iLO 3200 32 in. LCD Television
ILO 32 lcd
It is not cost prohibitive to repair time for a new TV I am afraid I can not give you an exact quote but a 32' Philips screen is 1100 dollars. Thats 200 more than I paid for the TV
Jun 07, 2008 | iLO V27DMBX Television
Hook up surround sound
if you are using a dirtv or other cable box, you should plug in the audio to your stereo from the cable box itself.
May 26, 2008 | iLO 3200 32 in. LCD Television
Ilo tv programming problem
get a surround sound system and once you hook up your audio you can then use the surround sound remote..avi in... to control your volume.. and use your direct tv remote to change channels
May 09, 2008 | iLO LCT32HA36 Television
32 in ilo lcd
your tv could have several problems, or one minor one, its hard to tell without seeing it, if you look through the back vents and the backlight is on ,it could be your lcd refractor board ,it could be as simple as a bad rca jack or rf jack depending how you have your tv hooked up , is ther a pic in any source mode,or are all dead, for example in vid 1 with a dvd player, if you get pic ,but in rf or reg tv no pic you may have a bad tuner or cold solder problems ,really hard to tell without more info sorry ,i hope i was helpfull
May 01, 2008 | iLO 3200 32 in. LCD Television
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
My Ilo tv
You cannot program a Direct TV remote for an Ilo.
Jan 22, 2008 | iLO 3200 32 in. LCD Television
Ilo tv
The Sony RMV210 remote will work on the 32inch Ilo and other HD tv's, that what makes it cost so much, but it will work
Nov 22, 2007 | iLO 3200 32 in. LCD Television
AM/FM Stereo Hookup problems
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
Nov 03, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
130 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
