Question about Sony Televison & Video
Convergence failed - Sony Televison & Video
  • Sony Master
  • 8,457 Answers
Can u do basic soldering?U have tools,like a soldering iron,desoldering pump and solders?The tv convergence board have fail,must replaced 2 STK convergence ICS and some or all it resistors to solved convergence picture problems.Tries websites like Tvrepair.com,Tvrepairkit.com to buy a convergence kit to repair it ur self.Or the shop,will cost u $300-350 for parts and labors.
Posted on Oct 02, 2010
  • Chi Chu Oct 02, 2010
    Sorry,websites are Tvrepairworld.com,Tvrepairkits.com have those convergence kit and instructional cd come with it.
How do I fix a Sony Rear Projection television with convergence issues?
the convergence circuit probably failed. there are resistors that I remember would burn up and cause the convergence ICs to fail. I would check with a servicer to see if the parts are even still available.
Sep 30, 2015 | Sony Televison & Video
Picture not in focus
Devices: All projection TV's (HD or analog), especially Samsung
If its a Samsung HCN653W (or similar model), the first thing to try is the menu option named "Magic Focus", which tunes the set's focus.
Otherwise, it sounds like a job for a convergence. Perform a convergence procedure on your TV, and if the problem recurs within a few days/weeks, then your TV's 'convergence amplifier' board (aka "convergence amp board") is starting to fail.
This board may fail completely, in which case, your convergence procedure will fail to improve the picture.
A "convergence procedure" can be performed entirely by just using the appropriate setup menu option and your remote control.
This board may partially fail, in which case your convergence procedure will properly converge the Red, Blue, Green colors on just part of the screen, whereas a properly functioning convergence amp board will allow complete convergence of the colors across the entire screen.
Your TV's convergence procedure instructions will be found in your TV's Owners Manual.
At least one Projection TV manufacturer recommends that the consumer perform a convergence procedure every 30 days, but most TV owners find that excessive, and might only do one when (a) there's an evident color convergence problem in any part of the picture, or (b) once every 3-6 months.
How-to video: www.youtube.com/watch?v=esk4nYZKFcg
how-to instructions: www.ehow.com/how_2034880_perform-convergence--tv.html
cost to you: $zero
If the convergence amp board is bad, cost for a service call would be $300 (USD) plus $100 for a new board plus 50% markup on parts = about $450 (USD)
Cost to order a new board online: about $100 (USD) + shipping + sales tax.
Alternatively, if you can solder/desolder STK's (Power Amplifier Integrated Circuits), one can repair a convergence amp board for as little as $30 (USD) or so.
Dec 04, 2011 | Sony Televison & Video
Automatic convergence feuses
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 13, 2011 | RCA HD52W66 Projection Television
Magic focus does not work. RGB projections do not line up.
That symptom is usually caused when the convergence ICs and associated resistors fail. You can get convergence repair kits for the various Hitachi models from www.tvrepairworld.com the kids contains both ICs and the associated resistors plus the CD with repair instructions.
Jan 07, 2011 | Hitachi Televison & Video
Convergance problem
Hi, I`m assuming your going into the menu and trying to adjust convergence and the lines won`t align? If so the convergence IC`s have failed and that circuit will need to be checked to see which parts have failed and then replace them, probably time to call in a tv tech for that one, video-tek
Jun 09, 2009 | Samsung HCN436W 43" Rear Projection...
Can't control red convergence on VS-45607
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
Aug 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Convergence prob for d52w26 rear projection tv 52"
If the auto-convergence is not working then the convergence amp ICs are starting to fail. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. These are large black ICs attached to a heatsink and should be marked STKxxx.
Keep us posted.
Dan
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
Warped picture
Good Day, jamelpp;
Sounds like the warped picture may be caused by the convergence output IC's, but try this first:
E2RESET DOES NOT RESET THE CONVERGENCE. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12598970", IF THIS DOES NOT RESET THE CONVERGENCE TRY "MENU 125968970"
Good Luck, big IRISH.
May 09, 2008 | Mitsubishi VS-45607 45" Rear Projection...
RCA HDTV bought in 2006. The picture has a "curved" appearance and the colors blurr together.
Failed convergence circuit and the problem can be the convergence power supply, convergence amp bd. or even the defelection/power bd. You will need a qualified tech to diagnose the problem. Sometimes these bds. will develop bad connection but most time it is a failed part.
Apr 13, 2008 | Televison & Video
Bad convergance, blurry
you are having a convergence fail. would need to replace the STK convergence ICs. they are probably going to be STK392-040 and there are 2 of them. you would also need to check all the pico fuses around the area.
Feb 20, 2008 | Samsung PCL5415RB 54" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
