Question about Texas Instruments TI-83 Plus Calculator
How to fix the burn marks on display or can display be fixed or replaced?
My curling iron has left a burn mark on my laminated bathroom vanity. How can I fix this?
No need to worry, as long as the burn mark is not too deep, this is a quick and easy fix.
Begin by wiping down the surface using a rag and soapy water. Next you will need to make a paste using baking soda and water (three parts baking soda to one part water) and apply over the burn mark. Allow this paste to sit for 20-30 minutes. Next you will need to use an old toothbrush and scrub the area until the mark has disappeared - you may need to apply more paste. Wash away the mess.
Since your vanity surface is laminate - as long as it is white - you can use plain white toothpaste instead of the baking soda/water mixture.
Sep 04, 2012 | Belle Foret Furniture
No pix on model # TLX03210B red light on power board flashes. smells burnt but no noticeable burn marks
I just got through fixing one with same problem and same model.There is 2 capacitors side by side that is 10Uf 450V.I replaced those and fixed my problem.
Jul 22, 2011 | Polaroid TLX-02311B 23 in. LCD TV
Displaying on the LCD display, E 007
Fixing film problem. Sensor cannot detect the white marking on fixing film due to worn-out or torn film. Try calling the nearest Canon service center for the replacement of fixing film unit.
Sep 22, 2010 | Canon imageRUNNER 2000 Copier
Is plasma burn in real?
Hello.
Well it does not catch any real fire if this is what you mean. What actually happens - PDP (Plasma Display Panel) is "burning out" throughout it's use. Especially if someone is watching TV channels with fixed logo (Like CNN for example). That steady image can get "burned in" into the screen and stay there forever. So it is important to watch different channels and programming so screen does not get any permanent "marks" and spots.
LCD and LED technology does not have this issue because of totally different method of producing image on the screen.
Regards.
Russ.
Aug 18, 2010 | Televison & Video
1990 mark v11, both the dash and tail lights out? fuse replaced.
may be the switch, these dash mounted head light switch had problem with the electrical connector burning.
Mar 07, 2010 | 1990 Lincoln Mark VII
My GE refridgerator is not keeping my food cold. The freezer appears to still be working but the digital display in the fridge seems to come and go.
That interface part number WR55X10503 may just be the problem. It senses temperatures in freezer and fresh food compartment and relays that information to the motherboard to keep temperatures where you want them. You can unplug refrigerator and then take the control out or down far enough to examine for burn marks or heat. It takes a special tool to diagnose the power from the motherboard and to the digital controls. Even if an authorized GE Technician comes out he or she would not waste the time to check it they would quickly replace it or the motherboard until fixed. If dispenser controls are OK and nothing more than the lights fading in the display I would switch that out after I had a look at the motherboard on both sides for burn marks or signs of heat. If you would like my assistance I would be glad to help out, I will return with a service manual and parts links.Thanks, Sea Breeze
Feb 19, 2010 | GE Profile PSW26P Stainless Steel Side by...
Burnt marks in my projection tv. Can it be fixed
if they are burn marks they must be present at all times when the tv is on if they are actually on all three picture tubes(CRT) it might be an expensive repair. Sometimes the burnt mark is only present on one of the three crts, a product of a on screen display left on for too long or the failure of a deflection yoke or something similar. the way you can find out if its a G/B or R crt,is when you get a commercial or a scene with a full G,B or R background you'll see the burnt mark on the screen that is damaged. picture tubes are replaceable but somewhat expensive. good luck and i hope i answer you question to your liking, if so please leave you pos feedback at this site. thanks!
Aug 22, 2009 | Mitsubishi Televison & Video
Arcing Microwave Oven
Look in cavity for any burn marks. If burn marks are present sand and paint area. You have to use paint made for microwaves. If no burn marks, Flash coming from magnetron and it would be time to replace. Yes it can be a safety concern, I would not use until fixed.
Mar 11, 2009 | Kenmore Microwave Ovens
Frigidaire Dryer Model FLGB43RG
those "burn" marks if they have an arking shape to them are smudges from the felt that goes on the drum support above and bellow the door inside the drier. the felts wear out every five to seven years or so. easy repair. send me a model number and i could go into more detail. part numbers ect.
Sep 23, 2007 | Zanussi TC7114W Electric Dryer
Texas Instruments TI-83 Plus Calculator Logo
43 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
