Question about Sony KP-51WS500 51" Rear Projection Television
Turns on for 30 sec then goes bright blue and goes back into standby. turn back on it does it agian
  • 10,594 Answers
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
Posted on Oct 02, 2010
    Sergeant:
    Champion:
  • 431 Answers
Look inside to see if red and green light up, if only blue going into shutdown, turn the blue screen adj. all the way down ck the hv splitter it is not the pic tube
Posted on Oct 09, 2010
Bush tv 3 weeks old, tried turn it on but just a black screen,standby light turns blue as if it's on also if I press any buttons on it the blue light flashes like working but just a black screen
Here goes:
#Press and hold the on/ off button...
#Whilst holding unplug the plug from the wall...
#Continue holding for 30 seconds...
#Plug in the plug whilst continuing to hold the on/ off button...
#Continue to hold for a further 30 seconds...
And the screen should come back on!
Jul 23, 2016 | Bush Televison & Video
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Model KV35540 Series #9017817 goes to standby after 30 sec
OLD set, most likely the picture tube has aged and only hope would be if the master screen inside the set is turned up just a little it may function again. If doing that (taking back off) be careful and also look in neck of the picture tube to see if the 3 filaments are faintly lit.
Only chances are no filaments or screen set too low from old age.
Nov 01, 2012 | Televison & Video
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Turns on scan and then just stops
i have a jetta 2000 ... 2.0 am facing problems with my speedometer which is suddenly indicating 240 km then going back to normal speed, once i press hard on the gas when ever the indicator reach max speed while am driving at 100 km hour the engine stops . also lately the engine would start for 30 sec and turns off, i by passed the car to a scanner it show i got a problem with the speed sensor, also sometimes while driving in up the hills the transmission starts getting weird , as if the gear box is sliding a big, then when turned off and on agian everything goes back to normal
Dec 03, 2009 | Medion M3 Composer 5100 PC Desktop
My Sceptre LCD TV (X32GV-Komodo0 power turns on
1. check power supply
2. check flyback
Ether or you have a ppower fauilure in the unit. and its probably blowing fuses.
Aug 31, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
My Sceptre LCD TV Power turns on briefly (blue
Power supply is the place to look, look for bulging on top of the capacitors in the secondary side of the main power supply.
Aug 29, 2009 | Sceptre X37sv-Naga 37 in. LCD Television
Tv prob
This is the common symptom of defected IC memory 24COxx,replaced this IC so it will works normal again.
Feel free to ask whatever the result...
Hope this may help you;
DON"T FORGET TO RATE:
Sep 04, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KP-51WS500 51" Rear Projection Television Logo
673 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
