Question about Echo CS400 18" Chain Saw
My saw won't start. how can i check the ignition?
  • 252 Answers
Pull the kill wire off at the ignition coil - retest for spark , if now spark faultry kill wire or switch indicated
but if no spark fit spark tester in line with h t lead and spark plug
gap tester is basically a piece of wood with 20 mm hole in middle and a hole drilled through to centre from opposing sides
the a nail that fits firmly is pushed through 1 on each side
and meet in the middle of the hole , but the points of ecah nail must align together and be exactly no less than 6.00 mm apart from each other ( place the tester inline between h t lead and plug ) use whater adaption you may need to connect to the saw
and pull the engine over as you would
if all is well the spark should jump across this gap and the gap at the plug while under compression pressure
you will see it in the the tster window
if no spark coil is problem
replace coil and set air gap to 0.010" and refit wires ands covers
cheers hope it helps
pauly46
Posted on Oct 02, 2010
My o34 Stihl chain saw ran good one day the next day won’t start I rebuilt cab got fire no start I tried starting fluid in plug still no pop to try to start saw is 34 years old well maintained
Have you checked the compression on the cyl. A saw that old may have lost compression and also have you checked the muffler to be sure it is not plugged. I base this on you saying you have fire to the plug.
Oct 08, 2017 | Stihl Garden
1998 dodgeram 1500 won,t start won,t turn over
check for power from the ignition in the start position to the starter relay/ solenoid terminal.
Jan 28, 2014 | 1997 Chrysler Town & Country
Won't start; plug looks good and has spark and it's getting fuel
Did you use the right fuel mix.? Does it still have good compression.? Have the piston rings been damaged.?
Check ignition switch.
Dec 20, 2012 | Husqvarna Chain Saw Models 371, 372xp
Intruder won't start battery gets hot
Could be the stators & regulator/rectifier if its over charging the battery. I'm not a mechanic just saw this video on youtube cause I'm having problems with my electrical system as well and trying to figure out the problem. http://www.youtube.com/watch?v=MWU2TbEePsY
Sep 16, 2012 | 2001 Suzuki VL 1500 Intruder LC
Makita concrete saw, no spark, new ignition coil.
Check clearance between the coil and magnet, too far away and magnetic field won't generate.
Apr 13, 2012 | Makita DPC7311 73cc 14Inch Gas Powered...
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Jan 01, 2018 | 2002 Saturn Sl
Won't stay running
in can be a number of things to check main thing is piston and rings , crack in the fuel line , ignition coil , or check valve in carby , air leak in crank seals
Aug 16, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My chain saw won't start. I don't have a spark, even though I changed the spark plug.
The trouble is more than likely a bad CDI (Capacitive Discharge Ignition) module.
Jun 28, 2011 | Husqvarna Garden
1999 Dodge Ram Conversion Van won't start. After many attempts the battery finally died but before it did it was making a clicking noise when we tried to start it. My husband saw a spark under the...
I hope that you have disconnected the battery fire could happen relay click's but will stick at drain could be the fuel pump you hear with the continuse click you might have a shorted starter.I think thats the first place to start.A bad ignition switch will cause this to happen sometimes?
Jan 11, 2018 | 1999 Dodge Ram
18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Feb 18, 2010 | Poulan Garden
Echo CS400 18" Chain Saw Logo
347 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
