Question about Linksys WRT120N Router
My new router WRT120N drops my wi-fi connection with everything in the house. I disable the security level from WPA2 Personal then turn the security level back than it works for 6-7 hrs after that it drops every device off. Do I need to get a new router?
    Problem Solver:
  • 7 Answers
To be more sure you can use wpa personal because wpa2 is not compatible with all of the wireless apdaptes, you can also upgrade the firmware of the router,
>>go to homesupport.cisco.com and download the latest firmware for the router and it will fix all the issue that you have
Posted on Oct 11, 2010
What is WPS pin mean?
WPS stands for Wi-Fi Protected Setup and it is a wireless networking standard that tries to make connections between a router and wireless devices faster and easier. It works only for wireless networks that have WPA Personal or WPA2 Personal security.
Dec 07, 2016 | Computers & Internet
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:
Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
May 25, 2016 | NetGear WNR2000 Wireless Router
I cannot connect. I keep getting a message "authentication Failed"
Do you connect your PC to router in an administrator role using web browser? Or do you connect some device to Wi-Fi network?
  1. Administrator role: You need to have correct login name and password for admin access. Search in manual or ask Google for default login name and password of your router type. If non-default password is set in the router then you must reset router setting and erase its settings to default (factory) status. You will lose all router configuration but default password is back.
  2. Wi-Fi client role: There are more possibilities why authentication fails in wireless communication. Mentioned error message describes what kind of problem occurred.
    (a) A password you put to client device does not match the wireless network password which is set in router. Your computer, tablet or smartphone WI-Fi interface must have exactly same password as WI-Fi network which is transmitted from router. Check and compare passwords on both sides, in client device and in router.
    (b) Client Wi-Fi interface security (encryption) mode differs from Wi-Fi network encryption used in router. But the same mode must be set on both sides (client and router) for successful connection.
Encryption modes are
  • WPA2 Enterpise
  • WPA2 PSK ("home")
  • WPA Enterprise
  • WPA PSK
  • WEP
  • No encryption (open)
Higher position - better security. Enterprise Wi-Fi modes require security devices like authentication servers, certification authorities etc. They are not used in home networks usually.
Jan 21, 2016 | Computers & Internet
How can i connect my samsung tablet to my wireless internet?
I assume you are either unable to see your network listed or when you select your network from the list of active Wi-Fi Networks within range of you device and depending on security level no password or the Security Key you have doesn't work. First, make sure you have a few pieces of information: 1) The SSID or name of the network 2) The security type and password 3) If no DHCP service you'll need the ip address subnet and an available address for your device, ip address of the gateway/router, & ip address of the DNS servers. Usually the router provides DHCP and provides all of the addressing information.
Typically, you are provided the SSID and a security key or password. On your tablet open settings and turn Wi-Fi in necessary and look for your SSID in the list to the right. If your SSID is not shown verify the name, that the router is on and you are within range. Be aware of obstructions between you and the router. My Pool House is a virtual dead zone due to some electrical wiring on the wall it shares with the office. The router is less than 5 feet away, but the signal is unreliable. If everything is working and still no SSID on list, then it may be hidden. Simply, select Add Wi-Fi Network at the bottom and enter the SSID (Netgear987), security type (WPA OR WPA2 typically) and the password (PASSWORD maybe case sensitive). If it connects and fails to obtainan ip address or just drops it may indicate another layer of security that requires each device MAC ID is added to the list of authorized devices for that router. Your MAC ID is listed on the Settings_About Device_Status screen WiFi MAC Address: (F7:C7:AE:78:E6:FC). Sounds like a lot but usually verified SSID and password do the trick. Good Luck
Apr 29, 2014 | Samsung Tab Tablets & eReaders
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
Setting secured wireless connection
You can enable WEP on your router.
In the address bar of your browser, type 192.168.0.1 to access the setup page of the Dlink router.
By default the username is admin and leave the password blank.
On the Setup page, go to Wireless.
Security Mode should be WEP then click Next.
You can change the WEP KEY 1. Make sure you remember this because you will need to enter this on your wireless computer.
Save the settings.
I hope this helps!
Jul 19, 2010 | D-Link DIR-625 (790069292637) Wireless...
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
Zoom 3G router. I have a pin on my 3G modem - how do I configure Zoom 3G router to use this PIN or do I have to disable the PIN on the modem
A Pin...this means that when you first connect you are sent to a special site, and you have to enter a pin on a web page? Or you have to have a special app to enter it?
Disable it, and use WPA security with a good (decent length, not dictionary based) pass phrase. Is the wire to your modem the insecure piece? Or the Wi-Fi that is accessible to someone in the adjacent street?
Unless your circumstances are odd, the wire to your modem is as secure as the interior of your home, while the wi-fi need to be well locked down. WPA2 with a good passphrase is as good as it gets. Well, using actual wires is faster, more secure and more reliable. But WPA or WPA2 is fairly good (WEP is fairly useless, it has been thoroughly cracked now and can be hacked with the right toolkit in a minute or two).
Jan 11, 2010 | Zoom (5590-00-03) Wireless Router (G66115)
How to fix my blackberry that tells me that the W010: Wi-Fi connection fails
Is the security level (WPA, WPA2 etc) selected on the router compatible with the Blackberry? Have you entered the passkey correctly allowing for case sensitivity?
Nov 27, 2009 | Actiontec GT704WG Wireless Router...
I have a apple. i want to put a password.. wpa security. how do i do this?? i have searched all over. the set up cd is only for pcs..
you want to put a password on wpa security...
here's what you do, actually you are going to open the firmware of your Wireless Router.
Open Internet Explorer, at the "search engine" just type the Gateway Address (192.168.x.x) then ENTER. After that will asking for Login: admin Password: admin __ this time your on the firmware of the Router. This time will appear and select for putting a password on wpa security. Hope this might you the steps. Good luck!
Aug 05, 2009 | Trendware TEW-432BRP Wireless Router...
Linksys WRT120N Router Logo
788 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
