Question about IBM ThinkPad T60 Notebook
Both my wired and wireless connection are not working on my T60 laptop running Windows XP Pro. The control panel shows the device functioning normally and it acquires network address when ethernet cable is connected. Still the browser cant connect to internet Can anyone please help ?
    President:
  • 1,851 Answers
Have you checked at the connection tab - lan settings (for Internet Explorer browser)? Maybe a proxy server is enabled.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Oct 02, 2010
Reinstalled wp on Gateway 400vtx and now the wired internet connection drops out in about 1 min and I get noe connection on the wireless.
Thank you for your kind words, we try very hard to resolve people's problems so a solution can be reached.
Apr 06, 2012 | Gateway 400VTX-3501335 Notebook
I installed windows 7 to my laptop and now the fn f1 button to get my wireless turned on doesnt work i need the drivers for it ??
yes you need to download the drivers for wireless card from the manufacturer's site and after that will work ...The function itself its still working ..but it has no driver to work with ..In case it will not work try the button for enabling wireless or try to enable the wireless from the task-bar tray or from network folder ..or from control panel ..
If you did not find the card in any of these places take a look in device manager (click right on computer and select properties and device manager ) and in there look under network devices and see if it is proper installed or not ..If it has issues will appear in yellow with an ask sign on it ..
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/lifebook/
this is the link for FAQ for this model ..
http://support.ts.fujitsu.com/Download/ShowFiles.asp
this is teh link for drivers.
The issue is that there are no drivers for windows 7 ..but download teh driver for windows xp ..and before installing open the folder and click on the executable right ..(click)
select properties and open the compatibility ..and in there select to run in compatibility with windows xp sp2 or sp3 and apply ..After that run the driver and if it says it can load it ...look and select to run it in compatibility ..
May 20, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Nov 13, 2009 | Motorola Mobility S805 Wireless Headset
Wireless will not connect Wireless network shows all 5 bars but will not connect I have upgraded the Intel Pro/Wireless 2200BG from the Tosiba site and flashed the BIOS per the Tosiba site, but it still...
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 03, 2009 | Toshiba Satellite M45-S331 Notebook
I cannot get my Netbook to connect to my wireless network. I have 3 other devices that connect just fine. What am I doing wrong?
Windows XP:
Click Start
Click Disable
Windows Vista:
Click Start Logo
Click Disable
Sep 24, 2009 | HP Mini 1000 Netbook
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
Home networking Windows XP
Often this is a simple power management issue. On the laptop check the wireless properties and disable allow Windows to turn off this device to save power.
Apr 05, 2009 | Microsoft Windows XP Professional
Intel proset wireless 3945ABG no adapters found
You need to disable the Windows Wireless manager in order for the Intel app to take over control of the wireless adapter.
Start
Run
"services.msc"
Find a service called "Windows Zero Wireless Configuration". Stop it. Set it to disable.
Try rebooting the machine and the Intel app should work.
Mar 22, 2009 | Computers & Internet
A recent mac laptop with Tiger & bootcamp/win XP will connect to the internet via a Netgear DG834G adsl modem with ethernet cable in tiger & XP but only in xp with wireless. Any advice? JL
If I understand you correctly you have an Intel based MAC, with the boot-camp boot manager, so you can choose to boot either from the native MAC OS or from Windows XP.
The system works fine from the MAC OS, but the (wired) ethernet does not work from XP.
1) When you boot into XP mode, the XP operating system is in
charge and the MAC OS is dormant.
2) Check the XP device manager to see if the ethernet NIC
(network device) is properly installed and if the device
drivers are functioning.
From Windows XP:
Right click My Computer ==> Properties => Hardware ==>
==> Device Manager ==> Network Adapters =>
==> Your network controller
Right click on your network controller ==> properties
Check the device status !!!
2) If the device is NOT working properly, you may need to
download and install a device driver for this card.
3) If the device IS working properly, you may need to run
the NETWORK SETUP WIZARD from the control panel:
START ==> Control Panel ==> Network Setup Wizard ==>
==> Next.
4) Assuming you are connecting to DSL with a login password,
use the: "My computer connect to the internet through a
modem" option.
If your DSL is always on, or if you use a local router to
connect to the DSL modem (the router does the work)
Then you choose the: "My computer connects to the
internet through another computer or a residential gateway"
option.
Martin
Apr 22, 2008 | Computers & Internet
IBM ThinkPad T60 Notebook Logo
135 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
