Question about Philips Televison & Video
Philips 52inch - Dual picture with red background Model No. 55PP9401 Serial No. 65136479
  • Philips Master
  • 8,617 Answers
Sounds like the convergence ICs number STK392-120 need to replace both of them. You can get replacements at the following link and they provide free instalation instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Posted on May 26, 2008
Picture is dull. red looks black
CRTS picture tubes have bad and dirty coolant chemical in it.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a CRTS coolant chemical kit with a intructional DVD dsic show u how to change it.
Jun 01, 2011 | Philips 55PP9401 55" Rear Projection...
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=55PP9401&slg=en&scy=US
PDF download of your Owners' manual:
http://download.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at http://www.philips.com
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
Sony 52inch KDFE42A10 picture gone, buzz, red
Yes. It's in the owners manual. Lamp model # XL-2400 , p/n 93087500
Apr 20, 2010 | Televison & Video
Intellisense button
If the model number on the set is 55PP9401/55 you have an interesting set----this model says Philips but was made by Hitachi---they made them for Philips for one year while Philips was gearing up to produce their own sets---very good set and is better than the Philips sets that came after it.
It uses (if it is this model) two STK-392-110 CONVERGENCE IC's----both need to be replaced and the set adjusted---no need for an original remote---with the set engaged in the convergence adjustment mode( there is a micro switch on the front of the main circuit board) A HITACHI REMOTE CAN THEN BE USED TO ADJUST THE CONVERGENCE. Hope this was helpful.
Aug 11, 2009 | Philips 55PP9401 55" Rear Projection...
Problem with HDTV on my Philips 55PP9401.
it is not reccommended for game console to be played on a projection t.v because projection tv's have three color bulbs in them and the conversion is different and if it happens to work it has been known to have burn the games image in the screen after awhile.. usually the store doesn't tell youthat unless you ask them about playing game consoles on a projection tv
Dec 01, 2008 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 Green Out?
This is a PP15 Philips Chassis Designation.
It's based on the DP15 Hitachi Chassis w/ Different Micro.
Hitachi DP15 Model: 53UDX10B
It's most likely that the convergence amps have failed and if you have little experience in electronics I'd STRONGLY suggest you take this one to the shop.
This set takes two STK392-110 Ics and it's recommended you upgrade those to the STK392-150s for greater reliability.
They make a nice kit complete with all conv. Ic's and all (6) resistors and complete instructions. Tritronics carries them part # X480295 (Jt22053 Repair Kit).
Bill
Nov 24, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Sep 25, 2007 | Philips 55PP9401 55" Rear Projection...
Ghosts in Tv Projection TV
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Aug 02, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 55PP9401 no sound no picture
When Replacing the (STK'S Power Pak) for this set you must use OEM parts. After market I.C. will not work!!! They will give you problems like you are discribing. D,TV
Dec 14, 2006 | Philips 55PP9401 55" Rear Projection...
Philip Model 55PP9401
The Green is Standard, meaning it is what you should lign the red and blue up with. But if it's not true in shape there is something wrong with the green.
Nov 28, 2006 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
