Question about ION Audio iTTUSB Turntable
I have an ion turntable, when recording the tracks keep on jumping, how can i solve this problem
  • ION Audio Master
  • 5,349 Answers
First make certain the record is clean with no dust or anything on it. If that doesn't work increase the weight/pressure to the stylus, by using moving the weight on the end of the arm. Ideally it should bet set to that recomended by the cartridge maker, so check that.
Posted on Oct 02, 2010
My need on my turntable jumps around on my records
If it keeps sliding in one direction, it probably needs an anti-skating adjustment or to be put on a level surface. If it jumps all over, the stylus weight is probably too light or the surface it's on isn't stable enough.
Sep 24, 2012 | Sony Audio Players & Recorders
Not all of the sound/music is being transferred from the LP.Hard to explain, but its when the LP has sound coming out of each speaker independent of one another, only one side is coming out on the recorded...
I know this is an old post, an I dont' have a solution yet, but t seems the same problem as on my Ion USB recorder - One of the input channels is not working. Like you, I found one of my music tracks not plying right - there was only the instrumental and no vocal. When I experimented, and changed round the jacks on the cable coming from the turntable (red and white plugs), I then got only vocals and no instrumental. Obviously one of the input sockets on the USB recorder is no longer working (I already checked the turntable and cable itself by playing back he same track with both stereo channels through my amplifier). You can either get the item replaced if its still under guarantee, or fix it yourself, if you have the necessary skills, neither of which apply to me.
Apr 22, 2011 | ION Audio Vinyl Recording Turntable
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
1-I'm recorded my music 10-track on step 3 on EZ Vinyl Converter. 2-On step 5 export recording to iTunes take tolong to complete. 3-I'm access iTunes Music library. I see only 3 music track. 4-Can you...
The software is not 'seeing' the gap between the tracks, so it does not know the song has ended. Untick 'split recording into tracks' box, then sit with it as it records and click on new track every time a song ends. Tedious, but it works.
Nov 29, 2010 | ION Audio TTUSB10 Turntable
Turntable plays fine, but when I play the converted tracks in itunes, they are very low
Try turning up the GAIN (a knob at the back of the turntable). This should increase the recording level.
Feb 16, 2010 | ION Audio TTUSB10 Turntable
ION TTSUSB10 does not record stero
I solved the problem by using www.wiki.audacityteam.org home page under the technology heading and clicking on USB turntables. The mixer had to be changed to 2 channels. (stereo)
Jan 05, 2010 | ION Audio TTUSB10 Turntable
Ion USB turntable is not recording both stereo tracks.
CHECK TO SEE IF YOU ARE GETTING SIGNAL ON BOTH CHANNELS OUT OF THE TURNTABLE IF ONLY ONE SIDE FAULT IS AT THE CARTRIDGE CHECK CONNECTIONS AT REAR OF THE HEAD SHOULD HAVE 4 IN PLACE
Oct 05, 2009 | ION Audio Vinyl Recording Turntable
Ion ittusb turntable interference
Please describe the conditions under which the noise happens. Is it always the same place? Whic is it - static or some other kind of interference? Read the following. If you're using high speaker volume to monitor while recording you could experiment with identifying it as the casue by cranking it up to see if you can make it worse.
As with any turntable the following advice for this one will apply:
The tonearm setup is critical for proper tracking. Do it again with extreme care if mistracking is your problem.
I found one model online and a review with some sample of music. Quite interesting...
http://www.everythingusb.com/ion_ttusb10_usb_turntable_13231.html
The author complained about some things that clearly mark him as a stranger to finer turntables. Complaining about having to assemble and position the 'rubber band', aka the drivebelt, and the tonearm counterweight shows that he underestimates the precision required for a mechanism to rotate at a constant precise speed while properly tracking the microscopic undulations of the groove without skipping into the air or gouging it to death.
Some basics when recording from a turntable...
1) Place the turntable as far from speakers as possible on a solid surface that you will not touch during the recording
2) Keep the volume low enough that airborne sounds don't cause mistracking of the stylus *
3) Avoid anything that will cause vibration or movement of the turntable. (Tip toe)
* If you have a subwoofer, turn it off.
Some advice after reading the article: don't try to save recording time by playing the discs at 45rpm. The best tracking of the disc and recording of the minute details in the grooves will be at the nativespeed of the recording. Digital manipulation later only gloms up the accuracy you probably want.
In general, the fewer the conversions steps in the analog domain, the better; and the fewer the bit rate conversions in the digital domain, the better.
Mar 26, 2009 | ION Audio Vinyl Recording Turntable
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
Appears to be installed properly but doesn't record
What computer, and are you using the ion software, or 3rd party software to record?
Keep me posted.
Dec 09, 2007 | ION Audio iTTUSB Turntable
ION Audio iTTUSB Turntable Logo
114 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
