Question about Toro Lawn Mower With Toro Power Tools
Ran mower week prior. fuel'd sarted and than died, tried several times after, pulled air box replaced filter, still the same
    Problem Solver:
  • 5 Answers
Sounds like some trash made it's way from the fuel tank into the carburetor. Or it could be a clogged fuel filter. What's the model number of the mower and engine?
Posted on Oct 03, 2010
2002 Cavalier starts then dies. Started about 1 week ago. Let sit overwrite started fine next afternoon. Ran great for several hrs. Started dying again. Replaced fuel filter, Ran great for a day. Now it...
Had a 89 cavalier did that start then die it map sensor. Also check ground wires if the become too corroded they won't start sometimes just run weird
Jan 21, 2015 | 2002 Chevrolet Cavalier
Engine won't start, doesn't seen to be getting gas.
Potential 'air lock' - try running with out fuel tank cap on
Cap should have a fine breather hole in it
May 03, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troy built mower honda 160 engine oil leak around governer shaft. no oil seal but shows one on parts breakdown. Can not find part number for shown seal.
Drain oil from mower until proper level. Remove spark plug and pull starter rope several times to blow out cylinder. Spray starter fluid in cylinder pull rope several times to clean out. Replace fouled plug with new spark plug. Remove air cleaner, ensure no oil present, replace filter as needed. Clean air filter box with carb cleaner. Install new air filter reattach filter cover. Prime engine, pull starter rope 1/2 way 4 times to help prime, then pull starter rope fully up to 10 times to start.
May 24, 2012 | Troy Garden
My John Deere stx46 riding mower acts like it becomes starved for gas after using for hour or so. Fuel filter is new, gas line new, coil pack new. Ran fine last year. Filter will be emtpy when dies, then...
Try loosening the gas cap a little...... there is a normally a small breather hole in the top or underside just above the seal which allows a small amount of air to enter into the fuel tank. Sometimes this breather hole gets clogged..... stopping air from entering into the fuel tank as fuel is used. Eventualy enough vacume pressure accumulates inside he tank causing a vapor lock. If you loosen your fuel cap slightly.... this should prevent the problem your experiencing. If it does... try soaking cap in deisel fuel or heating oil overnight, remove and allow to dry prior to re-installing. If the problem persists after a good soak, only option is to replace fuel cap. GOOD LUCK!
May 14, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
Yamaha 6600de generator dies 3 seconds after starting
When you pull the bowl off of your carb is it clean? If not you have some contamination possibly inside. You might want to remove the carb and blow compressed air through all the vents a ports.
Sep 24, 2009 | Reliable Yamaha YG4000D 4000 watts/33.0...
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Fuel problem on Sanderson 623 teleporter
Wow.....I never knew they made DIESEL lawn mowers. Sweet!
But I tell you this, I can almost guess to a "T" they have the same problems a Cat C-15 475HP diesel motor has when she runs out of fuel, and which you already done.
Air Lock. Like you just said. I seen it many a time with those motors (truck driver here). I have seen them fight you time and again on bleeding air out as well, even having done it 8 times in a row, and taking 15 minutes.
What we used to do, is simply pull the air filters, and give her some Ether shots to get moving (rough idle) and get them to KEEP pulling fuel (and air too), and THEN bleed out the air. The point is to KEEP her running, and KEEP on bleeding, until she stops fighting you.
Worked every time. Though......don't empty much Ether into her, just AIN'T good for the cylinders, man! (I have seen some guys make those motors SCREAM off of 2 cans of Ether at once. The horror! The pain!) But the motors kept on motoring!
If you can keep her running off of just the Primer, then pump away dude, and bleed at the same time.......
May 07, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Toro Lawn Mower With Toro Power Tools Logo
55 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
