I have an iriver H340. I can not get it to sync anything. The PC recognizes it, if I check its properties on the PC it says the disk space is all used, but the screen on the devise its self says 0 songs, 0 folders and nothing plays. I no longer have the original disks and I need info as to how to revive this devise. Thanks, Jim
  • 2 more comments
  • jdelisle Oct 02, 2010
    Nothing showing. I think the iriver needs to be reformatted, how ever it does not appear like the formatting that automatically takes place when I right click on it and instruct to format. I am not given any format types to choose from for that formatting either. So I am still at the same point, next idea?
    Find Devise, right click it it opens to say it is a harddisk with 0 bytes, hit format, it warns everything will erase, i click ok, PC says formatting, time goes by it says its done, check properties and it still says all memory space is used up and nothing is on iriver. What next?
  • jdelisle Oct 03, 2010
    As I said in the first comments and questions, i don t have them.
  • jdelisle Oct 04, 2010
    I need to reiterate that I do not pocess the original disks and formatting does not do the trick. it there any solution as the last few only were items I had already attempted.
You will need to download the driver to get your H340 working again. Click on the link below to download:
http://www.driverslab.com/drivers/MP3/iRiver/H320_H340_1_06-Windows_95_98_ME_NT_2000_XP/8879.html
Posted on Oct 04, 2010
    Genius:
  • 1,035 Answers
Hi. Try to check if files in the device is hidden. On your computer go to folder options then select show hidden files. Then go to your device and check if you were able to view the files inside.
Posted on Oct 02, 2010
  • Angelito Rabago
    Angelito Rabago Oct 02, 2010
    Hi. Right click the drive and click quick format. Provided me a feedback if it is doing it.
  • Angelito Rabago
    Angelito Rabago Oct 03, 2010
    Hi. Try to reload the firmware from the cd that came with the unit.
  • 1,170 Answers
Format the disk from the device. Then try copying songs.
Posted on Oct 03, 2010
Iriver h340 hdd
The only results from a search for h340 is from Logitech, and this is a quote from Logitech support.
"Your Logitech USB headset doesn't require any drivers or software, other than the default device drivers built into your operating system."
If your device is indeed a Logitech headset then you might try this:
Unplug the headset
Click on start
Right click on My Computer
Click on Properties
Select the hardware tab
Click on Device Manager
Look for your headset and uninstall the driver
close all the windows and reboot
after it reboots plug the headset back in, the correct drivers should then install automatically.
Jan 29, 2014 | Computers & Internet
My h340 will hang up after playing about 20 seconds and will not be recognized on my computer. I use the reset button but it hangs up again. Any ideas?
I read a suggestion to connect it to the computer via the media port first, then to the data port. That fixed my problems.
Mar 07, 2009 | iRiver H340 MP3 Player
Window XP does not recognize my H340 after battery change.
H340 should show as a removable disk drive. Ensure it is formatted as Fat32, run chkdsk, or scandisk. Does the H340 boot into play mode? you did not say. I replaced my battery with no problems... so if it boots Ok it is a non-related fault.
Dec 02, 2008 | iRiver H340 MP3 Player
IRiver H340 firmware
with the hex file hold the navi button for a few seconds; you get four options select the general one then you will see an upgrade firmware option. select this the hex file on your player is your firmware it will then go through the upgrade process. don't touch while this is happening. it will turn off when done. then thats it. Be careful the version v1.30 will get rid of the video option go with v1.29 or less
Jun 16, 2008 | iRiver H340 MP3 Player
IRiver H340 Hard Drive Capacity Problem
The reset button will not delete any file or function, just press that.
When you connect your H340 to PC, you may right click the H340 drive icon, and select 'property' -> clean up drive
Mar 20, 2008 | iRiver H340 MP3 Player
Putiing music on the iriver h340
iRiver has a special DRM signature, and only recognizes certain file formats. iTunes will ont work with the iRiver,for instance. Here are the formats recognized:
MP3 file
: WMA file
: OGG file
: ASF file
: IRM file
What is IRM (iRiver Rights Management)?
The IRM is digital copyright information file designed by iRiver
Limited. The IRM technology protects copyright and property from
unauthorized usage of digital contents provided through iRiver
Limited.
Use the proprietary software found on the IRiver website to transfer songs. If they still won't play, run the songs through Media Monkey or another Mp3 Converter to make them playable.
-Tha Mp3 Doctor
Mar 13, 2008 | iRiver H340 MP3 Player
New Music files copied to my iriver will either not play or partially play
Backup the h340 to your pc, format the h340 hdd and reload it, refresh database.
Oct 17, 2007 | iRiver H340 MP3 Player
IRiver keeps loading and loading and ...
Just a thought, try removing the battery, then holding the rest button in for about 15-30 seconds, release it, then re-attach the battery, if that don't work, try removing the battery, then re-attach the battery while holding in the reset button, then release the button after about 15 seconds. Konqueror?, That's a Linux based file manager/internet browser, is it on your PC or the iRiver? If it's on the iRiver, then the operating system is more likely Linux based, and removing the battery then re-attaching the battery while holding down the reset button, should!!! (not everything works as it should) reset the machine.
Jun 18, 2007 | iRiver H340 MP3 Player
Iriver H340 - battery
Visit http://xushi.co.uk/index.php?title=revive_your_iriver_h320_h340_with_a_new_&more=1&c=1&tb=1&pb=1 to see how its done. Buy battery from link to ebay
Sep 16, 2006 | iRiver H340 MP3 Player
How do I put movies on my iriver H340
you need to use the software provided to convert the video files.
Aug 21, 2006 | iRiver H340 MP3 Player
 Grubhead
Grubhead
