Question about Whirlpool RMC275PD Microwave Oven
I need to replace light bulb in Whirlpool built in microwave model # RMC 275PD. Is it necessary to remove unit from wall to replace the light bulb?
  • Whirlpool Master
  • 9,098 Answers
It looks like it, but if you look at the diagrams, maybe not.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
You can download Whirlpool owner's manuals and installation instructions here.
Posted on Oct 02, 2010
How to change the internal light?
Hi Tony
Well, if the manual says nothing then I'd give it a go yourself.
Not sure about your particular unit. So.... it's up to you....
I found that my light was simply covered by a plastic lens plate. I flexed it slightly and it opened up. Others have a single screw to remove so that the lens moves to one side.
Then I reached inside and turned the bulb & remove it.
It was a low wattage bulb rated at the same voltage as the AC wall voltage. But it's often stamped on the side. Just match up the same base type and specs.
Is this your Microwave
Whirlpool Microwave Bulb Replacment
Hope this helps!
Good Luck
Jul 08, 2015 | Whirlpool Microwave Ovens
Interior bulb out in microwave oven (built -in)
It all depends on that all-important model number. So without that, we can only give a broad, generic answer.
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It's at http://031d26d.namesecurehost.com/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph, except to unplug the oven.
See these links before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Nov 27, 2012 | Microwave Ovens
How do you change the bulb in a Kitchenaid microwave Model KBMC140HSS03
Hello & Welcome to FixYa
To replace the light bulb first remove the screws located on the vent grill at the top of the microwave, tilt the grill back and then pull away to remove. After this open the light cover , you have to remove the screws so that you can discard the old light bulb and then replace it with a new one. Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
How do you change the light bulb on an electrolux built in microwave ?
It is indeed straightforward but it requires removing the 4 phillips head screws that hold the trim kit on. Then you need to remove it from the cabinet (along with unplugging the cord.) Once that is done you will need to remove the 4 black phillips head screws along the bottom part of each side, 2 phillips from the left rear and 2 security T20 screws from the right side. I found that removing the 2 screws holding the bracket on the capacitor and the front allowed me to move the light housing enough to get to the bulb. In my case the bulb had unscrewed itself. I am not a big fan of the engineering associated with this model or the labor that assembled it.
Oct 23, 2010 | Electrolux Over-the-Range Microwave
We have a Jenn Air Microwave Over our built in oven. The light is burned out. How do we replace it? it is a jmc 7010ADB. Thank you Jan G
Mine is JMV8166BAS over-the-range model, and yours may be similar. Disconnect electric source (pull plug, or turn off circuit breaker).
1. Locate and remove 2 Phillips head screws on top projecting from cabinet/wall,etc,
2. Carefully & slowly, slide entire front vent 1/4" towards your left simultaneously pulling toward you.
3. Remove vent filter, if any.
4. In very center maybe beneath filter space, locate approx.4" width aluminum colored metal cover, possibly held in place with Phillips head screw.
5. Remove screw, exposing small light bulb.
6. Gently pull back on bulb, replace with identical wattage, 120V bulb from big box or appliance store.
7. Human touch may shorten life of bulb, so carefully push wire prongs into plastic bulb inlet socket using whatever allows you to grip bulb in the limited space.
8. Reverse 5 - 1 for reassembly. Before replacing vent assembly, notice the small notched angle clips on the bottom before aligning to microwave unit, as these were slightly tricky on my unit when inserting & sliding assembly 1/4" toright.
Jun 30, 2010 | Microwave Ovens
Changing microwave light bulb
Check the owner's manual to see if yours is a model which allows access to the lights without pulling it down from the wall.
Accessing the lights on some models will require you to remove the oven from the wall.
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Many use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find handy exploded views and order parts by model number here.
Oct 06, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Replace light bulb on Whirlpool GMC305PDS07 Microwave oven without a $150 service call. (The bulb does not unscrew from inside the oven.)
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Mar 03, 2009 | Whirlpool GH7145XF Microwave Oven
How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Nov 08, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave Ovens Logo
1,923 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
