Question about Toshiba gigabeat S MP3 Player
Frozen Hey, I've had my toshiba Gigabeat S for 6 months. And now all of a sudden it is frozen. It turns on, but when I try to move nothing happens. I have never dropped it, I have never had a problem with it and now ... I need help i have no idea what to do.
    Problem Solver:
  • 24 Answers
I'm thinking the hard drive is messing up... you know when i dropped my gigabeat S30 it wasn't working n it was freezing and the video files weren't playing at all. it would freeze when i turn on or play video. then i turned it off and then back on using the battery switch. it said "contact the manufacturer for repair" with a yield sign. i really thought i killed it...but i still had my hopes high to fix it myself somehow n i really thought it was from the hard drive. so i took it in my hand and gave it a shake on my palm. like i actually hit it on my palm for once n then i turned it on and it worked =D fineee.... i was so happy n now it still works fine ;)
i hope that helps
Posted on Jun 07, 2008
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Screen frozen with only white box around the outside
if you have the initial executing files that were on your mp3 when you bye,
Format your Mp3 on PC by FAT32 format and copy those on your Mp3 player folder
Sep 27, 2009 | Sony NWZB135F MP3 Player
Frozen?
try turning off the battery switch on the bottom of the player. Use a pen point slide it to the left for about 15 seconds, then back to the right.
Aug 11, 2009 | Toshiba Gigabeat S30 MP3 Player
Gigabeat F40 Frozen.
I had the same problem, would not work and when it did it kept scrolling. Trick is to take the front cover off, and see if the control then works. If so, there are two strips on back of the battery as spacers. I took them off, put back together and have not had a problem since!
Jun 05, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
Frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Dec 29, 2008 | Toshiba Satellite L305D-S5895 Notebook
Frozen screen on Gigabeat S30
I left the Gigabeat on until the battery ran out. It then turned itself off automatically and allowed me to re-charge the battery. When I turned the Gigabeat on, it again worked perfectly,
Jun 23, 2008 | Toshiba Gigabeat S30 MP3 Player
My toshiba MES60VK wont turn ON
I am having the same issues, any luck finding a solution?
Apr 15, 2008 | Toshiba gigabeat MES60VK Digital Media...
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
Gigabeat frozen!
Hi Lorna, Yeah I found my Gigabeat froze a few different times when I was getting used to it. Solution: at the bottom of player there is a little battery on/off switch - its tiny and black but you would have needed to switch it on to first use it. Well turn it off here for 10 seconds and the on again. This removes all power from the hard drive and circuits which occassionally freeze. Hope that helps
Apr 23, 2007 | Toshiba gigabeat S MP3 Player
Gigabeat 40GB screen frozen
well, it would be really easy to take off the battery. The battery is simply plugued with a little 3-pin wire, u just pull on it and put it back in. Now to open that gigabeat, its pretty easy. I even got some images for u. Go at this website (its for the F10 and u have the F40, but its the same thing): http://www.angelfire.com/bug2/gigabeat/
Mar 24, 2007 | Toshiba Gigabeat F41 (40 GB) MP3 Player
Toshiba gigabeat S MP3 Player Logo
93 people viewed this question
Top Toshiba Audio Players & Recorders Experts
Electro Med Services...
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
