Error Code F20 on Whirlpool Model WFW9400SW00. What does this mean?
  • 212 Answers
SOURCE: No Power at Control Panel
sounds like a fuse issue. check the fuses.
Posted on May 24, 2009
SOURCE: Fault code F20 on kenmore he2t clothes washer
I had the F-28 code error on my 1-1/2 year old Kenmore HE2t. The door wouldn't unlock and I couldn't get the clothes out of it.
The repair tech, after calling other repair techs, decided it was the central electrical unit, page #8540540 (Whirlpool) -- now Part No. W10163007. I ordered it online for about $250 cheaper than the tech was going to charge (not including the additional labor charges).
Posted on Jun 23, 2008
SOURCE: whirlpool duet steam giving error
mmm
Posted on Aug 08, 2008
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Steam Washer WFW9600 F20 Error
"F20" is a No Water Detect error. It is an indication that you either have no water coming into the washer, or very little water at all. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
If you have NO water in the wash tub, check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify the Pressure Switch hoses are intact and connected properly.
- Verify wire harness connections at the pressure switch, inlet valves, drain pump and Central Control Unit (CCU).
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. Click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Pressure Switch - remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a plastic air hose attached. Verify the electrical connections are intact, and the air hose is attached and not cracked or leaking.
To access the Central Control Unit (CCU) - with the top panel of the washer removed, the CCU is located directly behind, and just above the rear of the wash tub. There should be a tech sheet directly behind the lower panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics and to verify the wire connections at the CCU. In addition, the tech sheet will also assist in how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
  • 561 Answers
SOURCE: what is an f20 error code mean?
this is known code even for washers straigt out of the box it mean there is a problem with water pressure. ensure the water supply is connected and on.
2 there is a Analog Pressure Switch located underneath the top cover in the back left corner of the washer next to the CCU it may have come loose find and reconnect if not it maybe defective.
replacement part no is w1o156252
3 possible flow meter is defective part w10110225
4 also check the internal hoses for leaks even a pin sized hole can cause the code to show up.
I hope this was useful.
Posted on Dec 12, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
How to fix F20 error code whirlpool duet
How to fix F20 error code whirlpool duet YouTube
https://www.youtube.com/results?search_query=How+to+fix+F20+error+code+whirlpool+duet
Sep 04, 2014 | Whirlpool Washing Machines
The computer panel says f 20, what does that mean?? And when I turn the washer on, I noticed that no water is going into the machine?? why??
The error "F20" means : Water Inlet Problem - no water or insufficient
water supply.
Several possibilities.
Have a look at this forum - several tests must be perform to clearly identify where does problem comes from :.
http://www.applianceblog.com/mainforums/whirlpool-kitchenaid/10201-fixed-whirlpool-duet-sport-f-20-error-code.html
Good luck
Jan 24, 2011 | Whirlpool WFW9400S
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
What does F20 mean. this us\ally happens during the first cycle.
as far as i can remember f20 means an outflow problem. On whitegoods.co.uk all machine faults are explained. Error codes can be quite vague and f20 could mean your pump has stopped functioning, you outflow pipe is kinked or you have an internal blockage.
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I'd like to know what the F20 message means on the Duet washer. I do not have a manual. Also, how do I get rid of it. Could it be an unbalanced load? Thank you for your assistance. Marilyn...
"F20" error code is a No Water Detected error. It is an indication that you either have no water coming into the washer, or very little water at all due to low pressure. If the pressure switch has not tripped after 6 minutes, the error code is displayed. This can be a potential problem with the following:
May 17, 2010 | Whirlpool GHW9400 Duet Washer
May 24, 2009 | Whirlpool GHW9400 Duet Washer
CODE F-20
F20 error code indicates water fill problem.
here is a link for details on this error(contains just few tips and remedies)
click here
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Dec 29, 2007 | Washing Machines
Washing Machines Logo
124 people viewed this question
Top Washing Machines Experts
