Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer: blows but will not heat
Help
  • Anonymous Feb 10, 2009
    I have the same problem I got it cleans professionally and I clean the lint every time I start it. It is gas dryer and takes too long to dry or many cycles to dry most of the time.
My dryer was blowing cold air but wouldn't heat up. I first UNPLUGGED the dryer and checked all sources of lint clogging(ie.filter, duct work, and lint shoot inside the back panel of the dryer itself). Finding those clear of debris, I then used a continuity/OHM tester to check all of the fuses/thermal limiters. Finally, after the fuses/thermal limiters turned out to be free of defects, I pulled off the heating coil. That is what turned out to be the problem. I replaced it and my dryer works fine.
Posted on Apr 03, 2009
  • 5,911 Answers
If your dryer runs, but does not heat, click on the following link for some detailed advice on how to diagnose and determine the cause.
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Most dryer heat problems are associated with clogged, or improperly installed ducting. It's much easier to rule out the external causes before inspecting the dryer interior. I hope you find this information helpful. If you need further assistance, please post back and let me know.
Posted on Jun 06, 2008
No heat on whirlpool dryer
should also tryif you have a old house with fuses sometimes you only blow a partial fuse your dryer might run but not turn the element on for the heat
Mar 29, 2014 | Whirlpool WED6200S Electric Dryer
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
My whirlpool AWZ2303 only seems to be blowing cold
If your not getting heat from the machine its probably due to a faulty heating element. You can get the part at an appliance parts shop by bringing them the model number or you can call in a pro repairman to have a look and replace it. Do it yourself is cheaper by far but can be difficult on newer machines like this one.
Dec 11, 2009 | Whirlpool Dryers
My Whirlpool geq8811ll1 dryer turns on and spins but doesnt blow
you probably have one of the wires not connected correctly. or you could have bad themostat.
Sep 01, 2009 | Whirlpool GEQ8811L Electric Dryer
My gas whirlpool dryer won't heat. Cool air does
Hi
Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Duet blowing breaker
the heating element is probably broken and shorting out, causing no heat and blowing the breaker. if you are mechanically/electrically inclined then take off the top and take a look, it should be obvious. if not, then you need to have a proffessional look at it.
May 27, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
377 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
