Question about Hotpoint RVM1425 Microwave Oven
I need to replace a fuse and would like to know how to replace it manually
  • Hotpoint Master
  • 9,085 Answers
Simply pull it out of the fuse holder, then install the new fuse.
Posted on Oct 02, 2010
Does this unit itself have fuses inside it? If so, how do I access them.
Shelia, A lot of microwaves do have internal fuses, Links below will show how to change them.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Fix Microwave Oven Simple Fuse Replacement
Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
Microwave Line Fuse Replacement Whirlpool Microwave Repair Part W10422951
Mar 21, 2016 | Microwave Ovens
How do I replace fuse
Well you need to find where the fuse is located, And determine what type of fuse is being used. So you know what fuse you need to buy to replace it.
How do you know you need to replace the fuse?
Aug 30, 2014 | Microwave Ovens
Replace fuse Kenmore 40188523011
If you know that a fuse is open, you need to find out why it went out before replacing it. There are typically three fuses in any given microwave oven. Line or monitor fuse, cavity temp fuse and magnetron temp fuse.
Oct 07, 2013 | Sharp R-1750 Microwave Oven
Can I replace an internal thermal fuse in my jmc7000 jenn-air microwave?
It doesn't have a thermal fuse, but it has a 20A ceramic fuse and on or around the magnetron it has a thermostat.
The 20A fuse (if blown) can be had in local appliance parts store, and places like Lowe's Home Depot, and Wal-Mart.
For the fuse and/or thermostat, you can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If the fuse is blown and it blows again, it may be a loose fuse holder, shorted high voltage capacitor, or door switch trouble.
If the thermostat failed, it's due to a magnetron overheating due to the internal cooling fan's not working, or just the magnetron itself going bad.
As a bonus, you can find your owner's manual online here free.
If you need further free help, let us know.
Oct 06, 2011 | Jenn-Air JMC7000 Microwave Oven
Microwave MH7130XEB-2 stopped working while cooking. Is now dead. Check plug and breaker box, they are ok. Is it an internal fuse? If so what part # do I need?
Hello :
Problem with the power transformer or the power PCB . Or it could be just a fuse . You need to check first . If it's the fuse , then that will be easy to solve , you need only to replace it with new one . But if the problem is with the transformer or with the PCB , you need to take your microwave to the service .
You could check for manual here :
Whirlpool MH7130XE Microwave Oven manual .
good luck .
rate please !
Mar 19, 2010 | Whirlpool MH7130XE Microwave Oven
Microwave doesn't work
the outer casing has to be removed, inside you will find a large fuse 10A> this protects the transformers and magnetrons, also you will find some smaller control circuit fuses, they are normally mounted on the circuit board at the rear of the control panel.
Feb 23, 2009 | Sharp R-820B Convection/Microwave Oven
How do I change a fuse in a GE JVM 1440 microwave oven? I have looked at all supporting material and do not know how and do not want to mess it up without having instructions. Thanks
Remove 2 screws from front vent cover and removed vent cover
Remove one screw from top of display
Gentley push display panel up about 1/4 inch and tilt the top toward the front.
Disconnect 3 thin gauge molex connectors
Disconnect 1 heavey gauge connector
Remove screw from grounding wire at botton of display curcuit board
Remove display panel completely
Remove grill from above display area
To the left is a 2 x2 inch square board
Coil, capacitor and fuse block
Remove fuse
Check fuse rating
Match fuse rating and replace
Jan 28, 2009 | GE JVM1440 Microwave Oven
My Sharp R-9h91b microwave oven stopped working
My solution is still visible here: http://www.fixya.com/support/t1083290-sharp_r_9h91b_microwave_oven
But it seems like the site is acting weird or something.
I don't have the other manual, but this repost of my answer covers it all:
Hi, I'm the guy who gave who the service manual link and the long, very detailed answer that covered just about everything that can make a microwave "dead".
You don't actually need the base service manual since this manual has everything you need to locate the parts and the part numbers, as well as the overall schematic.
The magnetron temperature fuse (ref # 1-7, original part # QFS-TA013WRE0) is located in section 3-D of the exploded view on page 25. Physically, it is clipped onto the waveguide above the magnetron and it looks like the right item in the attached drawing.
The oven thermal cutout (TCO) (ref # 1-8, original part # RTHM-A024WRE0) is located in section 2-H of the exploded view on page 25. Physically, it is located on the left side of the chassis near the convection fan assembly and it looks like the left item in the attached drawing.
The best place to order whichever of these you might need is parts is Tritronics. If the part numbers have changed, that will show up on their Web site.
The testing of these parts is simple continuity testing: With your meter on the ohms scale (and oven power unplugged of course) measure the resistance at the terminals of the thermal cutout (TCO). It should read virtually zero. If it reads high / infinity, then it's open and needs to be replaced.
You can also place a jumper or clip lead across the bad (or suspected) device and plug the oven in just long enough to see if it comes to life. Do not cook with the jumper in place, and unplug it right away, avoiding contact with any inside wires or connections.
The schematic on page 4 shows you the "order", if you will, in which the current flows. (Yes, I know it's AC). From the plug, it goes through the oven thermal cutout, then the magnetron temperatuere fuse, then the line fuse.
On that schematic, the very bold black lines show you the essential path required to get power to the board's low voltage transformer, which should result in a lit display assuming the boar dis okay.
If you need more help, please feel free to write me at prototech@usa.net.
If this is not a FixYa, I don't know what is! *grin*
Oct 01, 2008 | Microwave Ovens
GE MICROWAVE FUSE REPLACEMENT
i have a galanz microwave i need to replace the fuse and i dont know wht to buy
Dec 21, 2007 | Microwave Ovens
Open Questions:
See all Hotpoint RVM1425 Microwave Oven Questions
Hotpoint RVM1425 Microwave Oven Logo
60 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jim Thurston
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
