Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Can I use my ultra lix 2000 to vaccum my new ceramic tile and wood floors? It so how do you stop the beater brushes from turning so that they do not scratch the floor?
  • 490 Answers
Yes you can, just set the height at maximum.
Posted on Oct 02, 2010
  • vickiediel Oct 02, 2010
    There is not height adjustment on the canister ultra lux 2000 vaccum. Could you explane.
  • farmerbear
    farmerbear Oct 03, 2010
    I apologize, I had the wrong machine. I will check my info and come up with something more useful:)
    Farmerbear at FixYa.com
Oreck xl commercial spits out dust on bare floor but work on carpet. It is about 15 years old. Bag has been changed. Brushes are spinning so belt is working. Started about 2 weeks ago. HELP!
It might be that the beater brush is spinning when you tip it up to look at it but slight pressure of it contacting the floor is enough to stop it. If it were my machine I would remove the beater brush and clean it as best I could, paying particular attention to the end pieces on the brush that hold it in place. A little WD40 between the end pieces and some twisting to be sure it worked in well. I would then reassemble with a new belt being sure it is on correctly so it turns the brush in the proper direction.
That is about the least expensive thing(s) you can do at this point before going further. I have one more potential cause, but it is best to check these first.
Please let me know how you make out.
Oct 06, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Our vaccum cleaner does not clean up.
If the floor unit is not picking up, check for a broken belt for the beater brush or for a frozen beater brush. Might be a good idea to remove the beater brush and clean it of any debris and squirt some WD40 on the two end pieces that hold the beater brush to the vacuum itself. Turn the brush by hand to be sure it is free and reassemble. Make sure the belt is properly attached so it moves the brush in the correct direction.
If you find this to be helpful, I would appreciate you providing me with a thumbs up rating. Thank you. Paul
Oct 03, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
My dyson has lost suction and the brushes do not rotate
Sounds like a broken belt may have been pulled up into the machine. Plan on replacing the belt and cleaning the beater brush. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt if needed, making sure the belt is put on properly.
Sep 11, 2010 | Dyson DC14 All floors Bagless Upright...
Carpet
have a look at the brushes are they turning and if they are can you stop them turning if you tuch them with your hand??? if you can stop them turning the brush drive belt is slipping get a new belt and fit it,,
problem sorted!!!!
Jun 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
How to use my staem cleaner
Follow the link below to download a copy of the User's Guide.
http://www.bissell.com/searchresults.aspx?searchtext=25A3&searchType=search&mode=userguides
The wood floor cleaner will work on your tile.
Jun 17, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Twirly thing under the vacuum has stopped spinning
there is a belt that drives the beater brush. flip the unit over, you can remove the bottom cover by removing a couple of screws. to one side of the brush you will see a channel where the belt should be. go to you local walmart, sears or hardware store and in the vaccume section they will have belts, on each bag of belts will be a list of vaccumes that belt fits simply find yours. with the new belt simply lift the beater brush out at the belt channel side and install the belt around motor shaft and brush. then place brush back in place , be suer brush guides are in properly. this should do ya.
Aug 18, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Beaters stop when vaccuming rug...didn't when new
I believe you need to change the belt that drives the brushes. When it gets stretched out, it will just spin on the axle of the motor or spin on the brush and smoke.
Jim
Jun 01, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
339 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
