Question about Steinberg Cubase SX3
Drums on sx3
I have not got a midi key board how do i put a drum track down without one, i can get the Lm7 up but now im stuck. thanks
EZ Drummer is an awesome tool I use to record the drum tracks to my Cubebase...The basic model itself is worth the purchase, and the EZX add-ons are innexpensive as well. Check your local music store and let their PC experts guide you. Good luck;)
Posted on Jan 04, 2009
  • 3 Answers
Hi!
You can put the drums manually with the drum editor. To do that, place the left and right selectors (the blue zone you can loop), I mean select an area first. Then, double-click in the area, on the track you want to make the drums. A midi segment will appear on the time-line. Double-click this segment, and it will take you in a drum editor. It's easy to edit, you will get to know it fast.
Posted on Jun 05, 2008
Hand brake stuck on
This can happen when the cable gets rusted in the sleeve. Track down problem by blocking wheels, Place vehicle in park, put keys in your pocket, release handbrake, then get under vehicle and check tension on parking brake cable. It should have slack. Check both back drums. There will be no movement in the stuck one. Use a screwdriver to slacken off the adjuster so that you can remove the drum. Then remove/repair/replace the rusted or seized parts.
Mar 14, 2015 | Cars & Trucks
When i play the keyboard and record it. it does not playback what i just performed when i record drums it plays back fine only the keyboard. im using the mpk49
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
Aug 17, 2011 | Propellerhead Reason 5
Hey. Im having a problem with my samson g track when mixing down midi and audio. The midi comes out really quiet even though its on full volume. It doesn't mixdown correctly. I'm also finding it impossible...
MIDI isn't audio, think of it as a sheet of music. It still needs to be played to be heard. Not sure of your recording setup but the midi performance that you have needs to trigger a keyboard or drum machine or VST instrument of some sort.
Apr 01, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
Im trying to record vocals over a beat but it reocrds the beat aswell, why?
because the microphone picks up drums too... wear earphones?
Aug 26, 2010 | Steinberg Cubase SX3
I have nuendo 3 hooked up via midi out by a m-audio 1X1 usb midi cable to a yamaha qy70. The QY70 is receiving the signal, but, everything is coming in on midi channel one. Whenever I set the drums on...
the changes which you make should be selected and set to a default mode.other wise the changes will get deselected to what it was default before automatically. in some cases its the software issue,.so reload the software again as new and check out. also check the connections its a rare chance but many times its possible,
check out.keep updated.thanks.
Jan 25, 2010 | Steinberg Nuendo 3 for PC
Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Apr 23, 2009 | Music
Still dont get it
Hi Mark.
Siorry, but because of a fault with the system I am not able to reach you on the other thread.
Normalizing tracks means leveling volume settings for a group of tracks or samples to mix or combine them together without troubles like the ones you got.
to normalise tracks you can use the function built in on the Korg studio, see normalize in the software help.
When operating on MIDIs also remember that MIDIs are recorded on different channel (example drums, guitar bass guitar).eg:bTd Aerosmith MIDI archive
When you use them on a sequencer, and you operate on the volume, ensure
Mar 29, 2009 | Korg Legacy Collection
Drums for MIDI track to not work
I haven't ever used this program but it sounds like you have your MIDI channel assigned to the wrong number. The default MIDI channel for drums is channel 10. Assign the track you are trying to play drums from to channel 10 in your program.
Jan 18, 2009 | Sony Acid Music Studio 7 Full Version for...
Playing Roland RS50 through Cubase SE on a PC
Sounds like you may have a MIDI loop. If the Midi I/O Meters on the transport bar ar all the way up then that's the case. Uncheck the speaker Icon next to the track when you are playing.
It's also usually a good idea to have each track set to have it's midi input be just your controller, not "All MIDI Inputs" which it is by default.
Finally, make sure your instrument has "Local Off" configured under its MIDI settings. This prevents it triggering its internal sounds directly and forces everything to go through the sequencer.
If my advice was helpful pleae vote for me!
Nov 01, 2007 | Steinberg Cubase SX3
Open Questions:
See all Steinberg Cubase SX3 Questions
Computers & Internet Logo
107 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Donald Currie III
Level 1 Expert
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
