My Whirlpool LSQ9544KQ is leaking when it fills. How can i fix it? Jim
  • 1 more comment
  • azsxr Oct 02, 2010
    It's only leaking when it is filling with water
    OK I I found the leak,It's coming out of the pump. It has a pin hole leak on the front side of the pump.
    How do i replace it?
    Thanks I'll give it a try. Do you know of a good place to buy parts for this washer?
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the leak is from the inlet to the washer, so first of all check the inlet hose connecctor to see if there is leak due to bad connection, remove and check the filter for dirt or clogging.If not the leak can be from the washer drum , due to an overflow or a failure of the gasket., or a failure of the drain hose, drain clips , drain pump/valve.
SO the first thing is to fill and observe the leak from below so that you get a first hand observation of the leak area.
If inlet or drain hose remove clean and reset.
Posted on Oct 03, 2010
  • 4,323 Answers
Hi
The water leaking on floor can be a serious issue as this may cause the inside parts to malfunction or in some cases rusting of the body. To check where exactly it is leaking; inspect the leak while it is running. After the cycle is complete quickly turn off the power, lie down the machine on left/right side and check from where the water is leaking. If it is the hose or drain pump then check whether hose is connected firmly and is not cut. If it not the hose/pump inspect if the leak is on the drum corner or anywhere on the upper side of the drum. If it is on upper side that means the drum is cracked and it is a costly affair. However, if it is leaking from the circumference then it is due to transmission seal. To replace the transmission seal you'll need to disassemble the washer and the drum assembly. Please post back in case of any issues. Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Posted on Oct 02, 2010
  • Daniel Scott
    Daniel Scott Oct 02, 2010
    Hi!
    If its leaking while filling then its due to a faulty fill valve, the fill valve might have developed a leak or a crack. To access the fill valve take the two screws in the back that are connected. Now, pull the back of the cover towards you and lift it off. Check the three multicolored wires connected to the inlet housing that you have to remove.
    Daniel
  • Daniel Scott
    Hi
    To check/replace the pump lean the washer back to get access to pump. Don't forget to remove the hose clamps and hoses, remove retainer clips. Try to pry off drain pump with screwdriver. Put on a new drain pump
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
My Whirlpool ETIFTTXKO2 is leaking water inside the refrigerator. What is going on? What can I do to fix it?
is there a ice maker on this unit if there is its probably over filling the ice and leaking. Is there ice in the freezer it may not be getting cold enfough to freeze and that could be caused by a dirty coil in the back and under the fridge
Jan 19, 2012 | Whirlpool Refrigerators
Whirlpool DU943 leaks heavily when filling from
I doubt the H2O tank temp would have any affect... to fix the problem you will need to pull the unit out and replace the supply line from the valve to the elbow... I would recommend braided line.
If your talking about the fill tube that loops up the side of the unit it usually is just seperated at one of the fittings and can be pushed back intp lace or recalmped... otherwise you will have to purchase a new oem tube.
Sep 02, 2009 | Whirlpool DU943PWK - Multiple Color...
FRS24ZGE is not making ice had a water leak a while ago so the water was shut off fixed leak and it is not making ice rod for ice tray has been done for a while when the water was shut off door has...
Hi Jeff, Had same problem. Turned out that the fill tube for the ice cube tray had filled with ice. I solved the problem by removing the tube from the back and letting warm water thaw the ice. Reinstalled and it works fine. You may also want to try a blow dryer while still in the freezer, but that may take some time. Good luck, Jim
Jul 28, 2009 | Frigidaire Freezers
My Whirlpool washer leaks when filling. We have located that it leaks from the plastic liner. Therefore leaking water onto floor.
Hi, The plastic liner you are talking about, is it the outer tub? If you could get me a model#, I could look this up for you.
Please let me know if I can help.
Vic
Jun 01, 2009 | Washing Machines
My Whirlpool ultimate care is leaking under,I did check the hoses and they are okey. What could be the problem?.
Can you describe where the leak may becoming from? For example, near the front, from under the washer, or near the back.
If you notice a pool of water coming from under the washer near the FRONT, this is commonly caused by a leaking water pump. Since these pumps are sealed units and are considered non-serviceable, it must be replaced. They cannot be resealed or "fixed".
If the leak appears to be leaking from under the washer near the CENTER of the tub, either the tub seal is leaking or the air dome hose may have come loose. If the tub seal is leaking, it also must be replaced. If the air dome hose comes loose, however, the washer will never fill up all the way and will continuously run. This will cause a flood rather than a drip.
If the leak is coming from the REAR of the washer, this can be caused by cracked fill hoses, loose fill hose connections, a leaking drain hose, or a fill valve hose leaking.
Since you said you checked your hoses, I suspect a water pump, or something loose. Can you please confirm your symptoms and let me know?
Apr 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Water leaking from bottom
Replace water pump. Common problem. Unscrew the control panel ,two screws on each end. Flip control panel over and unsnap gold brackets from base to the back. Lift up housing and disconnect lid switch, remove housing. The water pump is in the front lower that has two hoses , disconnect hoses and unsnap pump. My sister fixed hers in about 25 minutes.
Apr 06, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
