Question about Scytek 2000RS-M Remote Control
Galaxy 2000 Rs-m
The system operates normally, but during the starting function the starter does not stay engaged long enough, thus causing the engine to miss fire. Is there anyway to keep the starter engaged longer?
  • Anonymous Mar 22, 2014
    System don't go off when I open door
    System won't work after 30 seconds
  • 366 Answers
Yes, you can connect the tach sense wire from the controller(2000rs) to a fuel injector , and select tach monitor in the programming (see manual, available at scytek.net) and it will automaticcally adjust the starter crank time, other way to go is to install a delay card, sutch as the k 141 multi mode timer, and set it to crank for 3-6 seconds when triggered
Posted on Oct 11, 2009
Why will it start only if I just bump the key?
What I understand from your posting is that if you use the key to start in the normal way, then it will not start, but if you turn the ignition on and 'bump start' the vehicle without using the starter motor, the vehicle starts. If this is correct, then the problem is that the starter motor is consuming all the power for itself and the resultant voltage drop means that the coil and ignition are left wanting for power. Thus you don't get a good enough spark when the starter is engaged. The causes could be a number of things:- a weak battery, dirty or incorrectly set spark plugs, bad ignition leads causing tracking, badly set points gap or dirty points. bad starter motor (worn brushes or 'leaking' coil windings).
Personally, I would start with getting the ignition system up to scratch, new points and plugs, then correctly adjust the ignition timing.
Rgs. Bob
Jan 10, 2016 | Cars & Trucks
Why does my starter engage for only a second, then spin freely after that. it was removed and tested at Autozone and passed. The starter stayed engaged during the test when no load was encountered.
Hi Anonymous
What I believe you've said is that you turn the key to start, the engine turns over for a second, then you just hear the starter spinning but no engine turn over. Yes?
Then you took it to Autozone and tested it and it stayed engaged during the test. The differences, possible or real here, are the load on the starter gear end, and the electricity driving it.
There are a couple things happening in the start cycle. The motor starts spinning and the solenoid pushes the spinning gear forward to engage the toothed edge of the flywheel. If the solenoid doesn't push enough, the gear won't engage. So, one thought is that there's an issue with the solenoid - it may push the gear out just fine, but lack power to keep it pressed forward if there is back-force from the engine.
If you have a poor connection to the battery, the solenoid may not draw the current to keep the gear engaged. Checking the hot (red) wire both at the battery and where it attaches to the starter is the primary diagnostic there. Even if the battery has a good charge, the current draw if starting is the heaviest load it encounters in a typical day of driving, so the ability of the battery to dump that charge quickly in a pulse of high current is also important, and non-corroded, tightly connected wires help.
The starter gear also has a clutch in it - akin to the freewheel on the rear of a bike, or a ratchet. This lets the gear spin faster than the starter motor once the engine catches, so that the engine doesn't essentially grab the engaged starter motor and spin it waaay too fast. letting back on the key lets the fast spinning gear disengage without trouble. If there is an issue with that clutch/ratchet, that might also be allowing the gear to spin without it actually pushing - like the clicker in a ratchet sticking so that it'll spin either way.
After that.... there is likely both a relay and a fuse for the starter. Not a bad idea to check that neither is blown, or, in the case of the relay, looking sort of browned and cooked.
Hope this helps!
D
Dec 05, 2015 | 2000 Oldsmobile Alero
Starting problem
I think what you mean is that the starter motor is operating normally and rotating the engine but the engine will not fire up.
There are numerous problems which could be causing an engine no start condition and it is impossible to say what the cause is in your case without physically checking the car and running a diagnosis to see what fault codes it is throwing.
Feb 26, 2015 | 2000 Ford Explorer
Sport
Hi Maury, Seems you have a number of different problems at the same time. The grinding sound when pushing the clutch pedal would seem to be the clutch thrust release bearing, which is located inside the bell housing and requires the removal of the gearbox to replace. The warning lights should come on each time the ignition is switched on and then they should extinguish after a few seconds. The illumination of these lights is a fail safe system to show that all warning systems are active. The radio will go off during the period when the starter is engaged as a relay shunts all power to the starter during that procedure. The starter motor uses more power from the battery than any other system. The manufactures have taken this into consideration when designing the circuitry and decided as many others have, to adopt the operation. If when starting from cold this does not happen and the radio plays, it is indicating either excessive drawing of power by the starter and may also be the cause of the grinding noise you experience? Regards John
Jul 21, 2013 | 2000 Jeep Wrangler
2002 grand am remote starter
The most likely cause is one or more of the safety features are engaged during the attempt to remote start. The lights should flash a sequence that corresponds to the reason for failure to start. Your owners manual will describe what the sequence means. Based from experience, I suspect that the hood pinswitch has malfunctioned or damaged so the system thinks the hood is opened thus preventing starting.
Nov 13, 2011 | Prestige Remote Start
Motor start but does not run
Are you saying that the motor runs until you stop cranking it? or just that it truns over while the starter is engaged but doesn't fire at all?
If it's running while cranking but stalls immediately after you release the key and allow it to go into the "Run" position, then the ballast resistor of the ignition system is most likely bad. The idea is that on older cars with electronic ignition, the starter motor caused such a big voltage drop on the cars electrical system that the ignition coil wasn't provided a high enough voltage for proper spark to occur, so they wired them such that the ignition coil could handle the low voltage which was present during the cranking of the starter, but when you stopped cranking and the engine was running normally, suddenly without the voltage drop of the starter, the voltage would be to high and would damage the ignition circuit. Thus a 'ballast resistor' was added to the ignition circuit and it is only in line when the car is in the "run" position. This allows the ignition system the proper voltage to operate whether cranking or running, but sometimes the ballast resistors go bad, causing the engine to run while cranking but causing an open circuit in the ignition system when placed in the "run" position.
Good Luck.
Mar 28, 2011 | 1993 Toyota Corolla
My car wants to keep starting even after turning the key off
solenoid may be sticking. Have someone start the car, if it sticks tap the solenoid with screw driver handle. If that stops the starter, replace the solenoid. If it were me, I wouldn't bother testing it and just replace solenoid.
May 09, 2010 | 1989 Ford Crown Victoria
Starter will not engage
This bike has an electrical starter. A few explanations could cause such behavior
  1. Current is reaching the starter. Check the gear pinion which is rotated by the starter. Normally the starters gears are sturdy but yours might have worn down so much that its skipping and thus not engaging the engine to turn the cam so the engine is unable to turn over. Also the timing must not be synchronized...................sodeep
Sep 03, 2009 | 2005 Harley Davidson XL 1200 C Sportster...
Installed a new stater, battery and alt or fine, car makes a clunck sometimes b4 starting
The ignition coil can't do what you describe.
It almost sounds as if you have some broken teeth on the flywheel that the starter engages.
I would remove the starter, loosen or remove the spark plugs to relieve compression, then have someone turn the engine byhand while peering into the bellhousing with a flashlight where the starter mounts and inspect the flywheel for damage.
With a tooth (or more) worn or broken off, when the Bendix throws the starter gear forward, it may be landing on top of a broken tooth, slipping off, then turning your engine over.
There may be enough tooth even if broken, to stay engaged once the starter has meshed.
Jun 11, 2008 | 2000 Ford Taurus
Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Dec 01, 2007 | Scytek 2000RS-M Remote Control
Scytek 2000RS-M Remote Control Logo
194 people viewed this question
Top Scytek Televison & Video Experts
Are you a Scytek Televison and Video Expert? Answer questions, earn points and help others
