Question about Worx WT301K Revolver 6.5 Amp 1/2" Blockbuster Hammer Drill/Driver Kit with Keyless Chuck
I would like to order replacement brush. Were can I order this
Hoover steam vac, center brush falls out repeatedly
Hey there! All the brushes have to work together to function properly. If the center brush is falling out the brush block assembly is broken and will need to be replaced. Follow the link below to place an order for a replacement brush block.
Search Results
Hope this was helpful!
Aug 02, 2014 | Hoover C3820 Commercial Steam Vac Black...
Why does my brush roller stop and heat up belts?
Hi! If you have replaced the belt with a new one and your brush-roll is still not spinning, your brush-roll may need to be replaced. Remove the brushroll and clear it of hair and debris. Spin the end caps with your hand. They should spin easily with no tension. Inspect the area on the brushroll where the belt rests on for damages. To order a replacement brushroll click on this link. Search Results It could also be that the incorrect belt is being used with the vacuum. Make sure you are using genuine Hoover parts when replacing the belt. Click on this link to order a replacement belt. Search Results & Search Results
Jun 09, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
My brush bar keeps falling down. We replaced motor but now the brushes don't spin.
Hi! If you've replaced the turbine & gear assembly and the brushes are still not spinning, a replacement brush-block assembly may be needed. The brushes counter rotate and need each other to spin. If a single brush is falling out, the brush assembly is broken. If the whole brush assembly keeps falling out, the drive pin shaft may be damaged. To order a replacement brush-block follow the link below.
Search Results
Hope this helps!
Jun 03, 2014 | Hoover F7425-900 SteamVac V2 Widepath...
Truck will not start, wanted to check starting celinoid1995 niss pick up
Solenoid Replacement
  1. Remove the starter.
  2. Unscrew the two solenoid switch (magnetic switch) retaining screws.
  3. Remove the solenoid. In order to unhook the solenoid from the starter drive lever, lift it up at the same time that you are pulling it out of the starter housing.
  4. Installation is in the reverse order of removal. Make sure that the solenoid switch is properly engaged with the drive lever before tightening the mounting screws.
Fig. 4: Exploded view of S114-605, 606B, 607 and 608SA type starters-1989-95 models (click image for zoom)
Fig. 5: Exploded view of M3T38482 type starter-1989-95 models
Fig. 7: Exploded view of S114-527A type starter-1989-95 models
Fig. 8: Exploded view of M1T60281 type starter-1989-95 models
Fig. 9: Exploded view of S114-703A type starter-1989-95 models
Brush Replacement
NON-REDUCTION GEAR TYPE
  2. Remove the solenoid (magnetic switch).
  3. Unfasten the two end frame cap mounting bolts and remove the end frame cap.
  4. Remove the O-ring and lock plate from the armature shaft groove, then slide the shims off the shaft.
  5. Unfasten the two long housing screws (at the front of the starter) and carefully pull off the end plate.
  6. Using a screwdriver, separate the brushes from the brush holder.
  7. Slide the brush holder off of the armature shaft.
  8. Crush the old brushes off of the copper braid and file away any remaining solder.
  9. Fit the new brushes to the braid and spread the braid slightly.
Use a soldering iron of at least 250 watts.
  1. Using a light-grade solder, solder the brush to the braid. Grip the copper braid with flat pliers to prevent the solder from flowing down its length.
  2. File off any extra solder and then repeat the procedure for the remaining three brushes.
  3. Installation is in the reverse order of removal.
When installing the brush holder, make sure that the brushes line up properly.
REDUCTION GEAR TYPE
  1. Remove the starter and the solenoid.
  2. Remove the through-bolts and the rear cover. The rear cover can be pried off with a small prytool, but be careful not to damage the O-ring.
  3. Separate the starter housing, armature, and brush holder from the center housing. They can be removed as an assembly.
  4. Remove the positive side brush from its holder. The positive brush is insulated from the brush holder, and its lead wire is connected to the field coil.
  5. Carefully lift the negative brush from the commutator and remove it from the holder.
  6. Installation is in the reverse order of removal.
Starter Drive Replacement
  1. With the starter motor removed from the vehicle, separate the solenoid from the starter.
  2. Remove the two through-bolts and separate the gear case from the yoke housing.
  3. Remove the pinion stopper clip and the pinion stopper.
  4. Slide the starter drive off the armature shaft.
  5. Install the starter drive and reassemble the starter in the reverse order of removal.
REDUCTION GEAR TYPE
  2. Unfasten the solenoid and the shift lever.
  3. Remove the bolts securing the center housing to the front cover and separate the parts.
  4. Remove the gears and starter drive.
  5. Installation is in the reverse order of removal.
Hope this helps (remember to rating this answer and leave a testimonial comment) Thank you for using Fixya.
Oct 12, 2011 | 1995 Nissan Pickup
Motor began to arc at brushes then blew a fuse, we have replaced the fuse however it blows immediately on start up. We have ordered new brushes and are in the process of changing them, however i am not...
If the motor starts sparking excessively at the brushes, apart from brush wear, the problem is normally a short in the armature windings which is unlikely to be repairable on a small motor.You could try cleaning in between the segments of the commutator with an old tooth brush and then replace the brushes. I have had the same problem with motors and replaced the brushes but have never had any success.
Aug 01, 2011 | Makita (MAK2414NB) 14in Cutoff Saw
My dremel works intermitently. As I move the switch from one speed to another it will momentarlly run. Whats the problem? THANKS
You described intermitten pwer supply, follow this procedure:
1. check your power cord for breaks or kinks, especially where it join the piece or plug
2. if cord is ok, check/replace brushes.
To check/replace brushes on dremel 395 follow this procedure:
1. switch off unit, remove power cord.
2. with flat screwdriver remove gently brush covers, WATCH FOR LITTLE SPRINGS!!!
3. check brushes for wear, springs if connect correctly, if brushes are thinner than 3.2mm (1/8") replace with new ones, this check should be carried regardless after about 50hrs of use, brushes last about 50 to 60hrs in normal use.
In unlikely case that it is switch, this is as well very easy replaceable.
1. switch off unit
2. remove cable from power source
3. remove brushes following previous procedure
4. remove collar from front of the piece
5. remove side screws and gently pry apart halves, label side up
6. replace switch
7. screw pieces back in reverse order
8. replace back brushes.
All parts are easy available, when purchase brushes or switch, be aware that they fit only particular model!
I would recommend clean table with butcher paper on top, torx/hex screwdriver, philips screwdriver, flat screwdriver - these vary from country to country, I cannot provide what exactly tools you will need, you need to check what screws are holding your piece together, little long nose pliers can be helpful as well.
As you pull handpiece apart put your parts in order in whihc you pulled them apart, when you put them back, it will be easy to put them back in reverse order in which them come apart. For changing brushes you need about 5min (assign 15min), for changing switch or faulty power cord you need about 1h (assign 3hrs), assigned time is theoretical, prctically multiply it by 3...
If you have anymore questions, or require more detailed instructions, do not hesitate to follow this thread and leave note.
Leave note how it go, thanx!
Aug 13, 2010 | Dremel Variable - Speed Multipro Rotary...
Broken Brush on Hoover SteamVac Need to order new brushes
Yes you can order a brush block. It comes complete it is around $35. You can buy or order them at any vac shop or call me at my shop and I can ship them out.
Josh 614.868.0799 m-f 9:30-6 sat 10-2
Dec 18, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
I have a Proheat 2X. The tough stain brush adhesive has separated from the plastic. How can I fix this or do I have to order a new brush?
Check brush belt and cleaning all......brush no brokner if you need replaced
Part no: 2036686
Brush - 6 Row (1) w/Swivel Arms
Nov 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
What do I need to replace the brushes in Bosch Bulldog 11210VSR
Were the brushes severely worn? It's really only the brush that you need to replace, as long as the spring didn't come into contact with the rotor and get worn.
Mar 08, 2009 | Bosch Drills
Can not find a new brush
You should be able to order thru a repair shop, you will need your model number. Are you talking about the brush roll or an attachment brush?
Jan 05, 2008 | Panasonic MC-V7720 Bagless Upright Vacuum
Worx WT301K Revolver 6.5 Amp 1/2" Blockbuster Hammer Drill/Driver Kit with Keyless Chuck Logo
43 people viewed this question
Top Worx Drills Experts
Are you a Worx Drill Expert? Answer questions, earn points and help others
