Question about Miele T9820 Gas Dryer
How do I replace the drum belt on a miele 9820 dryer.
  • 4,323 Answers
Hi
To replace the drum belt on a miele dryer you can follow this procedure--
1. Remove the front panel.
2. Slide a putty knife between the front panel and the top near a corner. Lift the corner and repeat on the other side.
3. To remove the lower panel, insert the putty knife between the panel and each side. Then twist to release clip.
4. Reach underneath drum and behind motor to locate idler pulley. Push idler pulley to left to release drum belt tension. Remove the belt from the motor pulley.
5. Loosen the screws that secure the bottom of the front panel to the dryer sides. Do not completely remove the screws.
6. Remove the drum and belt from the cabinet.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Oct 02, 2010
It's not hot enough-
Check that the exhaust vent/duct is clean and clear. If the exhaust airflow is restrict, it will effect the temperature of your dryer. Also, many dryers today have the lint filter. Make sure the filter is clean.
Aug 26, 2017 | Miele Dryers
How do i replace dryer belt
You have to disassemble your Miele dryer to get access to the drum and the belt for replacement.
Jan 14, 2015 | Miele Dryers
Im trying to replace the drum belt on a Miele t7734 tumble dryer, but cant seem to get around the front or back of the drum to get the belt around it. Am I supposed to dismantle the whole machine to do...
Some dryers disassemble from the front, making it possible to slip the replacement belt over the drum and connect it to the tension idler and the motor pulley.
Dec 20, 2014 | Miele Dryers
Drum not turning. There is heat. Opened machine found broken belt. Drum will not turn by hand. What would it cost to fix?
in the package of the new belt, the belt for the dryer the instructions are right on or in the package, if not normally you take the front and possibly the top of the dryer 1st.... off slide the belt over the drum, and the insert it through the tensioner and then unto the motor. you have to make sure the belt has tension on it this will show it will be able to move the drum.... you can download maintenance manual form here
http://www.slideshare.net/avermapub/miele-gas-dryer-t9820-service-manual
price depends where you purchase it.. $ 20 to $ 45
Sep 25, 2014 | Miele T9800 Electric Dryer
Dryer belt t9800 keeps breaking
worn felt seal on the front of the drum. felt has worn away exposing the rubber, when the dryer gets warm the rubber gets sticky. this causes loud vibrations and friction. the drum wont turn so the belt breaks. i would not trust this job to any one but a miele tech, as it is very complicated and someone that does not know how to work on this dryer can cause more harm than good.
Jun 17, 2012 | Miele Dryers
Miele gas dryer drum won't turn, but turns on like it works
check out my tips on dryers
the tensioner and belt needs to be replaced more than likely
May 09, 2010 | Miele T9820 Gas Dryer
Help - Miele Dryer Model T9800 problem!
The belt is most likely broken. The front drum bearing seal may have worn out and caused this to happen. Call Miele. You'll be better off.
Feb 18, 2010 | Miele T9800 Electric Dryer
The drum is not spinning on a miele dryer, model T5206, the appliance is generating heat, the brushes are intact and also the belt on the centre of the drum is intact.
the tensioning device [ spring] is weak or the belt is stretched beyond its usable length. if a new belt has been installed, the tech didn't put the belt on the correct side of the tensioning device. it is possible to install it wrong.
Jun 19, 2008 | Miele Dryers
Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Oct 14, 2007 | Miele Novotronic T220 Electric Dryer
Miele T9820 Gas Dryer Logo
522 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
