Question about Toshiba PDR-3330 Digital Camera
I have a Toshiba $GB SDHC Memory Card. I put it in the camera and camera says card is locked. I have slid the yellow lock button and it does not unlock. I also have PNY OPTIMA that has the same problem. Can you help me? Laurie sengo@cal.net
    Brigadier General:
  • 3,006 Answers
Your main problem is that you are trying to use a 4GB SDHC card in an approximately 8 year old camera which was only designed to accept a maximum 512MB SD card and which only worked reliably with 256MB SD cards. When your camera was designed, 128MB cards were the largest size available and so hardware testing only went up that far.
SDHC cards use a different memory structure to SD cards and older devices cannot use them even though they will fit in the slot. As it's a hardware limitation there is no firmware update option.
Your only fix is to obtain the correct type and capacity of SD card or to replace your camera with one which accepts SDHC cards.
I hope you manage to use this information to fix your problem or at least that it assists you to choose your next course of action. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 02, 2010
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
What does card protected mean?
Wheb you have a SD, SDHC or SDXC memory card and you put the switch to the lock position, the card is protected, That means nothing can change the files that are stored on the card. Not by wiring, not by deleting and not by formatting. Keep the lock with up, towards the golden connection points.
On the picture the 64 GB card is unlocked. `the 32 GB card is locked 8ab871eb-243a-48dd-a8d8-58e5df95d568.jpg
Dec 29, 2013 | Vivitar ViviCam 8025 Digital Camera
When putting a Lexar Multi-Use 16 GB SDHC memory card in my Canon Powershot A540 I get Memory Card Error message as well Card Locked message. Have tried unlocking it by the slide on side of card, is t
It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
Jan 03, 2013 | Canon PowerShot A540 Digital Camera
I bought two new 8GB SDHC memory cards for my canon ixus500. the old memory card is 1GB ad still works but i wanted more memory cards. neither of the two new cards work. they both say memory card error AND...
If your camera is the type that uses SD cards, then your problem is that the camera was developed in 2004 before SDHC cards were invented. Your camera cannot use them.
Sep 15, 2011 | Canon PowerShot S500 IXUS 500 Digital...
MEMORY CARD LOCKED SIGN COME UP UNABLE TO TAKE PHOTOS, HOW DO I UNLOCK THE MEMORY CARD?
Hello Carol,
If it is a SD or SDHC card you can see a little sliding switch on the left hand side of the card on the label side.
When this is slid down it locks the card.
Push it back up to unlock the card.
Hope this help.
May 27, 2011 | Canon Cameras
I have a SanDisk SDHC Card class 4 4 gb and it won't work in my Canon Power shot SD630, I get a memory error that says card is locked, however card is not locked, what camera canI use this card in?
The SD630 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
Your SDHC card can be used in any camera that accepts SDHC cards.
Feb 03, 2011 | SanDisk 4GB Secure Digital High Capacity...
My SDHC card is locked. When I put the memory card
The problem solved by using the proper SDHC card reader. It is working fine in the camera now.
Dec 29, 2009 | Cameras
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Toshiba PDR-3330 Digital Camera Logo
163 people viewed this question
Top Toshiba Cameras Experts
john milligan
Hjalmer Lamminen
Hjalmer Lamminen
Simon Flummox
Simon Flummox
Are you a Toshiba Camera Expert? Answer questions, earn points and help others
