Where is the filter on an xe80 trane res. hvac system is not in return in house.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 23 Answers
It might have higher end filter on in installed at the furnace or check inside of the furnace it should have a filter clip factory add.
Posted on Oct 02, 2010
How to add additional returns to furnace
You definitely could use a second return air duct, depending on how your system is set up. If it's in a crawl space it would be pretty straight forward to drop an insulated flex hose down and connect it to your plennum via a Y connection. You can get a floor grille with filter capability from your local lowe's or home depot, if they dont have it check with plumbing supply. If your system is above, like in your attic, it will be a little more difficult but still the same principle. Bottom line, adding a second return air duct will increase your HVAC systems efficiency greatly. I can't believe only one was installed by the original contractor.
Dec 14, 2017 | Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Would a home a/c stop dripping condensation after a tune-up WAY, WAY overdue?
It should drip. That's the humidity from your house. Call them out again to have them verify the drain pipe is clear. Tell them you think they did something wrong. If it doesn't drain right, it will pool inside the unit and cause the internal AC panels to rust if the drain pan (below the condenser) overflows. Or worse, it might be a source for mold to grow inside the system. The later being unlikely, but not impossible.
May 16, 2014 | Heating & Cooling
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
Oct 12, 2012 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
My trane XE80 will only blow cold air. The fan
It sounds like the problem is a tripped limit switch. Look in the burner compartment and on the blower assembly for a switch that looks like the one below. It will be about the same size round as a quarter. Press the red button on any of the switches you find, then re-try furnace.
Mar 23, 2010 | Heating & Cooling
Where i can found the ac filter, bacause i want to replace. tnks
AIR FILTER
DESCRIPTION
A dust and odor air filter is standard equipment on
models equipped with the three zone temperature
control systems. The filter element is the
same size as the front air conditioner evaporator to
ensure ample filtering capacity. A removable door on
the bottom of the front HVAC housing below the
glove box provides easy access to the filter element
for replacement. The filter should be checked and
replaced at least once every 24,000 km (15,000 miles)
and checked if heater-A/C system performance seems
lower than expected.
REMOVAL
(1) Locate the air filter door on the bottom of the
lower HVAC housing just outboard of the passenger
side of the instrument panel center stack.
(2) Slide the air filter door latch toward the rear of
the vehicle until it engages the opened stop on the
door.
(3) Pull the air filter door straight downward to
disengage it from the air filter opening of the lower
HVAC housing.
(4) Use your fingers to reach through the air filter
opening of the lower HVAC housing far enough to
grasp the air filter.
(5) Pull the air filter straight down and out of the
HVAC housing.
INSTALLATION
(1) Note the “Airflow” directional arrow imprinted
on the foam seal around the frame of the air filter.
This arrow should always be oriented towards the
center of the vehicle.
(2) With the air filter “Airflow” arrow properly oriented,
carefully slide the filter fully upward into the
HVAC housing through the air filter opening.
(3) With the latch still positioned against its
opened stop, reinstall the air filter door onto the
lower HVAC housing air filter opening.
(4) Slide the air filter door latch toward the front
of the vehicle until it hits the closed stop on the door.
Good luck
Dec 22, 2009 | 2004 Dodge Caravan
Not enough return air to heating unit
Right now you are at bare minimun for what your unit requires. If you are not having any problems with the unit or have not had any I would not worry about it. You need to check and make sure that your duct size on the unit is not smaller than 14" in diameter. If it is 14" or bigger you are fine.
Dec 03, 2008 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
132 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
