Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have an opener model no. 139.53515SR. How do I find out what the operarting frequency settings are so I can set the dip switches on the hand held unit. The original hand held unit is lost. Thank you for your assistance.
    President:
  • 3,197 Answers
You don't need to set the dip switches. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. While holding the button on the remote press and release the smart/learn button. Your remote should now operate the door.
Posted on Oct 03, 2010
I have a Heat and Glo gas log fire. It is switched on at the moment and won't switch off with remote. I have put new batteries in remote. Can someone tell me how to switch it off manually
I understand your frustration. Call 1 (888) 427-3973 if these do not work.
1) The on/off switch on the fireplace and/or wall may be in the on position. This will over ride the remote control feature.
2) The remote is in the thermostat mode (SMART-STAT and RCT-MLT models) and the temperature of the room has not exceeded the desired temperature setting by 2 degrees Fahrenheit or 1 degree Celsius.
3) Batteries in the hand-held transmitter are old and underpowered. May work up close and will not work a few feet away.
4) Hand-held transmitter is outside of the 25' of operation.
5) Hand-held transmitter has been dropped and the frequency has been moved off the frequency of the receiver.
http://www.heatnglo.com/Owner-Resources/Troubleshooting-and-FAQs/Common-Questions/Remote-Controls.aspx
Oct 25, 2016 | Heating & Cooling
How do I reset the hand held remote control to the ceiling fan?
I would be nice to know what make/model fan you have! Most have 4 dip switches in the receiver & transmitter. Just match the settings.
Aug 15, 2015 | Dryers
How to program remote
If it has dip switches...................Open hand held transmitter battery compartment and you'll see 4 or 5 dip switches. Match with dip switches on receiver and you should be good to go.
Jul 16, 2014 | Hampton Bay Dryers
I am trying to install a chamberlain wireless keypad opener. I have a Craftsmen door opener. In the instructions, I thought it told me to change on my car remote the DIP Switch for #1 to "-". My...
If you held the smart button in too long it erases the memory and none of the remotes will work. To program it press and hold the button on your remote and then press and immediately release the smart button.
Feb 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
How can I reprogram an old style 61LM to a garage door with a learn button? Thanks!
Th?? Liftmaster 61LM remote ?? th? equivalent remote tο th? Sears Craftsman 139 model number listed above. It h?? dip switches inside th? battery compartment th?t ?ου match up w?th ?ουr existing remote tο m?k? ?t open ?ουr garage door. Th?r? ?? ???ο a set οf dip switches οn th? overhead opener itself ?f ?ου nο longer h?ν? a working remote. It ?hου?? b? easy tο find οn th? garage door opener. Th?? remote operates οn a 390 MHZ Frequency, ?n? works οn models frοm 1984-1992 essentially.
There will be a colored learn button on the motor head. Press and release this button and then press the button on the remote. That is it. Thanks BB
Mar 21, 2010 | liftmaster Chamberlain Garage Door Opener...
Mind of it's own
your remote and fan is set to someone elses frequency by little toggle switches
you will have to remove fan to where it hangs make sure power off
find the remote sensor inside electric case at ceiling in the fan
this is a dip switch to control frequencies
09c4f2f.jpg you will see something like this adjust the dip switches
means change the dip switch for fan
then on remote open the remote battery pack find the dip switch in there
change those dip switches to the same as in ceiling fan
put fan together and turn back on power
your fan should now not pick up the other frequency of another remote and they have a span of about 50 yards to pick up frequencies
Jun 07, 2008 | Hampton Bay 24002 Ceiling Fan
Minka Aire Remote control R211
You need to change the tiny DIP switch settings so each fan is set up differently. (Note that each pair of remote transmitters--the one in the fan body, held in a bracket above the light kit when you drop that down; plus the one on the wall switch or in a hand-held remote, must be set with the same combination.)
Our Minka Aire Churchill model has 4 DIP switches; I have seen Casablancas with 5.
Jun 01, 2008 | Minka RC120 Remote Control
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
611 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
