We have a similar model's service manual at our site which will help you, but note that the part numbers will not be the same.
It's here: http://031d26d.namesecurehost.com/mwd//r1480_r1481_r1482_sm.pdf
If I had to bet, I would say the high voltage rectifier diode or high voltage capacitor shorted and blew the fuse.
Here are some links you
or someone you know can use for test help, but read their safety
warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's
probably okay)
http://www.gallawa.com/microtech/cap_test.html
Once you replace the fuse (15A or 20A fuse available at hardware stores, etc.), if it goes dead again almost
immediately after pressing the Start pad, that's usually a shorted
high-voltage capacitor.
If it goes dead
several seconds after pressing the Start pad, that's usually a
failing
high-voltage transformer.
If it runs fine but won't heat, you have a bad high voltage rectifier diode and/or magnetron.
A loud buzz, hum, or groan is usually a
shorted high voltage rectifier diode, but a sound like gurgling into an
empty coffee mug is one symptom of a failed magnetron, and yet the mag can
be bad without that sound.
You can order Sharp parts from
Encompass here
or you can call them toll-free at
866-779-5835.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
I had a typo in that URL. Should be:
http://031d26d.namesecurehost.com/mwd/r1...
