Question about GE 36 in. Profile JP969 Electric Cooktop
Fault Code Code F116 (or possibly F117) began flashing. Disconnected power then reconnected power. Now nothing on the cooktop works at all. Confirmed that there is power to the cooktop. Any suggestions? Is there a "re-set" button of any sort?
  • Anonymous Apr 23, 2009
    Same flashing too F1 16
Today F116 began flashing...what to do..its only 2 yrs old.
Posted on Oct 11, 2008
The red padlock icon that usually unlocks with the 5 second touch of a finger won't unlock the cooktop.
Have you tried disconnecting the whole cooktop from the main supply for about 5 minutes? Sometimes when reconnected the fault goes away.
Nov 28, 2015 | Cooktops
Had power go off now er flashing on all burners can not reset
It's possible that you had a surge when the power returned that scrambled the controller's brain. Try disconnecting power and reconnecting to restore normal operation. Disconnect power by unplugging the stove from the wall or switching off the breaker that controls it at your main circuit breaker box. Wait a minute or two, then plug the stove back in or turn the circuit breaker back on. If the stove does not work after this, you may need a new controller board.
Aug 06, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
May 03, 2014 | GE Monogram ZEU30R Electric Cooktop
Flashing lights wont stop
Possible this is an error due to a protection and so it cannot switch on the cooker/oven. remove power off and check the coils, check for leak to the body of the oven , if so it can trip on protection.Also check the sensors- thermistor sensors. Check for insulation failure and insects that are trapped.finally check the control panel for moisture and if so dry the panel and reconnect the connectors once again.
Dec 14, 2011 | KitchenAid 30 in. KECC506R Electric...
WHIRLPOOL AKR 301 IS FLASHING O3 F Fault code
Jan 09, 2010 | Cooktops
No heat cookop gives me code rf f156 , lf f116, rr f 146, lr f126
You will need a serviceman for this one as it is a serious problem.
note: rr is right rear, lf is left front and so on.
Usually this indicates a problem with the elements or worse - electronics (if it's the electronic version).
Jun 19, 2009 | GE 30 in.JP950 Electric Cooktop
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Cook top
Recommend you look up code in owner's manual. Since you did not provide make or model, there is too little to go on here...
Mar 25, 2008 | Cooktops
Error code
Same thing happened to me. Reset your stove top by flipping your fuse off. The stove top will reset and the error code will go away.
Jan 21, 2008 | GE 30 in.JP950 Electric Cooktop
GE 36 in. Profile JP969 Electric Cooktop Logo
563 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
