Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
A wood screw fell to the drain and short-circuited something. It caused a loud pop and sparks. I reset the control panel with heated dry, normal, heated dry, normal until all light went on. Then cancel. The dishwasher will not fill.
  • 11,896 Answers
Sounds like your pump got fried or shorted out.
Posted on Oct 02, 2010
Do these ranges have a fuse? Kenmore range 91195291992
The first item to check is the circuit breaker or fuse box. It sounds like you shorted one of the hot wires to ground and that will trip a circuit breaker or blow a fuse. Next, with the range unplugged, remove the back panel and inspect wires going to bake element. You should see a black mark where it shorted. Repair connection if needed. Replace panel and plug back in. Reset circuit breaker or replace fuse and see if unit works. If not, the loud pop could be the control. Good luck!
Jan 29, 2016 | Kitchen Ranges
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
No sign of life to our 5 year old D/W except flashing "CLEAN" L.E.D.
7-1 heating circuit problem control programmed to shut down machine when no rise in water temp during heat cycle, you either have an open heating element or wire burnt a shorted thermistor or a bad control not outputing 120VAC to the heater you can reset the control by placing the machine into diagnostic hit cancel button to turn off all the lights press heated dry-normal, heated dry- normal within 6 seconds lights should come on press cancel unit should start it will run till same part of cycle reached and lock out again if it has not been removed the little black panel below the door remove should have the tech sheet in a plastic pouch which explains how to check the components mentioned earlier,
Apr 03, 2014 | Whirlpool GU2800XTV Dishwasher
It wont start. the hi temp and heavy button are the only buttons that come on
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit/toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Hopefully some of that helps!
Jul 08, 2012 | Maytag 24 in. MDBH950AWS Built-in...
Washer will not start
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Jul 03, 2012 | Maytag Dishwasher
Dishwasher control panel unresponsive
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
Refresh control panel
Instructions
    • 1
    • 2
    • 3
      Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
    • 4
      Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
      Hope this will be of help to you
      Have an awesome day
Feb 08, 2012 | Kenmore Dishwashers
Error 1 on kenwood dishwasher
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 05, 2011 | Kenwood KDW243A Builtin Dishwasher
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
How to reset control panel on model 587.1517 kenmore dish washer
From what I have read elsewhere, the interrupt *may* have something to do with a thermostat circuit cutting out if the entry hot water is too high ( more than 145F) - it seems like a buggy safety feature i.e. the circuit board thinks that the water heater is overheating. The makers have apparently made changes to the control board to fix this bug but it costs serious $$$ to get a repairman in and buy the new board.
I prefer to use the reset code, and keep my water temp lower when using it.
Feb 20, 2011 | Kenmore Dishwashers
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
90 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
