Question about Homelite Garden
What should the high and low screws be set at?
    Scholar:
  • 150 Answers
Set the low speed at 1 turn out and the high at 1.25 out. Never adjust for max rpms that would be too lean and damage the machine.
Posted on Oct 02, 2010
  • b1023wolf Dec 20, 2010
    thankyou what do i do if this won't work
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
Hi, I have a Mac-3200 and need to know where to set the 3 carb. screws at. T, low and high I don't have a manual Thank you. Z-man
Most guys adjust them 'by ear'. Warm up the saw (hopefully you can get it to start), and set the high speed by opening the screw until it sounds like it is 'burbling' at wide open throttle. DO NOT adjust until it is screaming at its highes attainable rpm !!!! If you do, the mixture will be so lean it will damage the saw under repeated heavy load. Leaving it 'burble' at WOT (wide open throttle) will ensure that proper lubrication will be available in the cut. Under load, the burble will disappear and the saw should pull strong and not overheat, damage the piston or score the cylinder wall.
Next set the low speed screw until there is no hesitation in rpm increase when the trigger is pulled. Some suggest setting the low speed first then the high speed so you may have to readjust the high speed once the low speed is done.
The idle screw should be adjusted to where the chain is NOT rotating the guide bar at idle. If it continues to move, the idle is too high.
Nov 22, 2015 | McCulloch Garden
What is the factory setting for lowand high screws on 25cc craftsman blower
If the two screws are side by side, one is the high speed mixture screw and the other is the low speed mixture screw. To set the high and low adjustment screws, tighten the screws in until they stop, don't force the screw after it stops. Back each screw out 1 1/2 turns. The engine will start and run here if everything else is ok. Fine tune each adjustment screw by closing the screw off (CW) until the engine runs rough. Back the screw out (CCW) until the engine smooths out. Run the engine at full speed and adjust the high screw. Let off the trigger and adjust the low screw. Once the mixture screws are adjusted, you can turn the idle screw to adjust the idle speed. It can take some time getting it all adjusted.
Nov 20, 2013 | Garden
Stihl FS 80 carburetor settings for high and low screws
Hi F Del
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Oct 10, 2012 | Stihl Zama Fs-80 Carburetor C1q-s157...
I would like to get the proper settings for my low and high fuel jet screws on my 371k chain saw motor
theres no exact setting to use. and they are high and low air screws. the small flat head screw by the throttle lever on the carb is for fuel. but the best way to figure it out is to turn both air screws all the way in and the back out 2 and 1/2 turns. that a good starting point. from there adjust the low with the saw ideling till it sound good and the adjust the high with the throttle wide open till it sounds good.
Jul 08, 2011 | Husqvarna SM 125 Motorcycles
Homelite mighty lite 26ss - Carb needs adjustment. Which screw is which? What are the initial low and high screw adjustment settings? Thanks
Starting with the question which screw is which: the low speed screw is closest to the engine and that makes the high speed screw farther away. Set the screws 1 turn out and then adjust as needed.
Feb 14, 2011 | Garden
LOW and HIGH speed screw settings
you those to adjust the carb hi is balls out running , sometimes it sounds sick or spudders when cutting the hi will clean that up small turns only . low is for idle. ok
Feb 22, 2010 | Garden
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you aim headlights
The adjustment screws/nuts should be located either on the top of the headlamp assembly, behind the headlamp assembly, or near the frame rail by the radiator support.
You will have vertical adjustment screws for each independent beam (separate highs and separate lows, but will be same screw if highs and lows are the same bulb). You may also have additional horizontal adjustment screws as well
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
For Low Beams: If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
For High Beams (if separate from low beams): Aim the headlight directly at the line you marked on the wall.
Aug 11, 2009 | 2004 Suzuki Forenza
Garden Logo
328 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
