Question about Philips Televison & Video
I have a philips model 46pp9302/17 dptv330f chassis with a red conversion problem already changed 2 ic part# stk392-120 plus 4 resistors location# 3149 3150 3155 3156 these parts were burnt they are 6.8 ohm. after replacing these parts bow in bottom and top of picture are gone but I STILL CANNOT adjust conversion.
    President:
  • 2,712 Answers
It appears the red CRT will have to be manually adjusted. I would recommend calling a qualified technician to do this for you,as it is not that simple a procedure.
Try adjusting the convergence using the remote. Page 8 of your quick setup guide that came with the TV should give you the steps. If that doesnt work, I'm afraid the only other choice is to call in a service guy.
Please post back and let us know how it goes. If you find that my answer has helped you in any way, kindly take a moment to "Accept" the solution.
Thanks and good luck!
IrishDruid
Posted on May 26, 2008
  • 3,037 Answers
How are you trying to adjust the convergence? What is preventing you from doing it exactly? Please let me know and I would be happy to let you know what you need to do.
    Genius:
  • 1,665 Answers
It seems some electrolytic capacitors over 100v at area must be cheanged.
I have a Phillips DPTV335 with red ghost, I was giving 2 stk 392-110 to replace the original stk 392-120 well this work or do I have to change resistor values? Thanks for your help!
the 110 may work but you should always go back with the STK392-120 and also there are 12 6>8 ohm resistors that will need to be possibly replaced at least two will blow anytime an IC fails in that chassis so replacing the two ICs alone will most likely not fix the issue without the resistors being checked and replaced if any of the 12 are blown
Apr 04, 2012 | Philips Televison & Video
I HAVE A PHILIP PROJECTION MODEL 60P8341A, THE CONERGENCY IS OFF MAINLY THE RED VERTICAL BOTTOM IS BEND,WE CHANGE THE 2 IC'S AND THE PROBLEM IS STILL THERE,CAN YOU HELP. THANK YOU
did you check and replace any of the 6.8 ohm resistors? A phillips will almost always blow at least one of the resistors when the ICs fail. If the blown resistor isnt replaced the new ICs will fail almost instantly.
Mar 15, 2011 | Philips Televison & Video
I have a 2002 Philips 60 in. tv with the color
2) STK392-120 ICs and 4) 6.8 ohm 1 watt metal-oxide resistors.
May 06, 2010 | Philips 60PP9202 60" Rear Projection...
Philips 60p8342 chassy ptv 916
check all your solder connection and test the resistors on the conversion IC's , also check oscilating circuts
Oct 27, 2008 | Philips 60P8341 60" Rear Projection...
Rear projection tv
You will need to replace both convergence ICs they are STK392-120 and that model will also open 2 or 4 of the 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link with free instalation instructions with pictures as well as free tech support to help you locate the open resistors that will need replacement. Here's the link.
http://servicemanuals.vstore.ca/
Jun 26, 2008 | Philips 46PP9302 46" Rear Projection...
Ghosting RED HELP
You can get the convergence Ic's at the link I posted you need 2-STK392-120's also that model is known to burn the resistors on that set you may consider replacing your 4-6.8ohm resistors at the same time,At the link I posted you also get pic installation instructions as well as free online tech support.
May 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Philips 55PW9363 looks 3d
You need to replace both convergence ICs they are STK392-120 this is an easy repair that you can do yourself and save yourself around 400.00 for about 45 minutes work. You can order the new ICs at the following link and they provide free installation instructions with pictures and also free online support with a support tech while you do the repair. I am one of their support techs. You would also want to order at least 4 convergence resistors and they send the proper ones for your model as often a couple resistors go. Your model uses 6.8ohm 2watt 5% metal film resistors. So to recap you will need (2) STK392-120 Convergence ICs and (4) Convergence ICs . very inexspensive repair if you do it yourself. here is the link.
Apr 12, 2008 | Philips 55PW9363 55" Rear Projection...
Sony HS30 Convergance Issue
The STK ICs are located on the D board their locations are IC801 and IC 802 they are both STK392-560 and you will only have to remove the D board. Usually only 1 or 2 resistors go bad right next to the ICs heatsink. You can get replacements at the following link and they include installation instruction plus free tech support heres the link.
Apr 07, 2008 | Sony KP-46WT500 46" Rear Projection...
43P8341/37 tv is acting up
Generally, a convergence issue...requires chassis pull &
replacement of two IC's.....large STK's on largest heatsinks in set......up-grade for STK392-110,120 = STK393-160...I use
Hitachi # CZ 01341.....Do not use generics ! Also,check for
over-heated resistors near IC's....1 to 2 ohm.....1 to 2 watt.........
........................T.
Feb 09, 2008 | Philips 43P8341 43" Rear Projection...
Convergence problem on a Philips projection TV
They should be STK392-120 but check the numbers on yours to be positive. They are located on the extreme left of the chassis looking inside the back panel mounted on a heat sink. They will have STK Numbers stamped on them. Yes you should change both of them they cost 10.00 each at electronix.com You will need heat sink compound as well but this is better purchased at Radio Shack 2.00 per tube. Put a good coat of Heat sink compound on the back side of the new ICs. Also check over the resistors on the board next to the ICs sometimes 1 or 2 of those burn when the Cs go out. Let me know if you need anything further
Jan 25, 2008 | Philips 60PP9202 60" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
