Question about Eurodib CORT- L Indoor Grill
The thermostat COTHERM 3708 is burned. Where i can find that piece? The grill do not get hot because the thermostat is not working
Heater not working
Get a higher temperature thermostat. Fluid in the block warms up first and hotter then mixes with cold radiator fluid this lets it warm faster. Your current thermostat is opening too soon preventing it from warming the whole coolant system,also put a piece of cardboard across the grill to keep the radiator warmer.
Jan 02, 2015 | 1991 GMC Sonoma
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
Grill doesnt get hot it burns on low it starving for gas
blocked gas line / reg not working/blocked burner orfice needs cleaning , try these
May 22, 2010 | Char-Broil Advantage 463453306
Th unit is turning off on its' own. It smells
Please check your thermostat, it could be defective and
needs to be replaced. It is overheating at the moment,
and may bogged down anytime. That is why it is unusually hot. Please check the thermostat, before your
unit gets damage. Hope this will help you.
Jan 10, 2010 | Essick Air 4D7 800 13 Gallon Humidifier
Microwave wont light up while in operation.
have you ckecked the light bulb?
Nov 15, 2009 | Cars & Trucks
Grill Chef bbq not enough heat , goes up to 400%initially and back down to 250%. Has been cleaned thoroughly. Garbage?
if you want good constant hot fire change charcoal i switched from briqutes to lump or what they call natural charcoal i use royal oak but best choice also markets it. thing is they add starch to briqutes to make them stick together and burn longer thus reducing constant heat the natural lump charcoal work great for good hot fire ill assume your grilling steaks works great on them hope this solves problem
Aug 16, 2008 | Patio Classic Barbecue Bucket Grill
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Broken piece connecting timer and thermostat
These are the guys you need to speak to; http://www.esalton.com/control/contactus 1-800-233-9054 Hope this helps - please ask again if you get no luck from them :)
Apr 15, 2007 | George Foreman GGR62 Grill
Eurodib CORT- L Indoor Grill Logo
78 people viewed this question
Top Eurodib Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Eurodib Kitchen Appliances - Other Expert? Answer questions, earn points and help others
