Question about Creative Labs GigaWorks T20 Computer Speakers
I cannot get my t20 speakers working, i have just had a new sound card fitted, the green speaker level is going up and down but no sound
  • Creative Labs Master
  • 27,725 Answers
Control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Posted on Oct 02, 2010
Have a new computer that now has windows 8.1, no sound is coming from speaker, S120 speaker system. Can I download something to resolve this?
Check the following;
  1. Speakers plugged into the correct jack
  2. Speakers receiving power
  3. Speakers Turned On
  4. Sound not turned all the way down in Mixer
  5. Sound Not Muted
Jan 04, 2015 | Computers & Internet
Speakers, no sound
Since they were working, check the basics first.
  1. Check the speakers on another device. Mp3 player will work fine.
  2. check the sound card on your computer (use a set of headphones or another speaker set).
  3. If you find they weren't plugged in, powered on, etc. resolve that. Usually the power plugs are black, and only fit in one spot. The audio cable to plug into the computer is similar to a headphones jack (3.5mm). On most computers the audio output (speakers) port is colored green.
  4. If none of these get you fixed, go into the control panel and click the sounds icon. From there you can view your volume levels (is the sound muted?), view your playback device (it might have a hardware problem, or be disabled), and test the settings.
  5. If you are still stuck after this please also post your version of windows, and the make/model of your computer. If you know it, the type of audio device you are using would also be helpful.
Thanks for asking, and Good Luck!
Dec 18, 2011 | JBL CREATURE II Computer Speakers
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
Sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
Aug 03, 2009 | Dell Dimension 3000 PC Desktop
I have no sound on my laptop
is it a thinkpad t20? you need the sound card drivers.
drivers for the t20 available here
http://www-307.ibm.com/pc/support/site.wss/MIGR-4JSQHB.html
its under audio, select the one that is right for your operating system.
if its any other model or another brand those drivers wont work.
send me the brand and model in that case.
Thanks,
Ekse
Jun 03, 2009 | IBM ThinkPad T20 2647 Notebook
Extended my monitor to a Vizio 37" LCD TV Echoed Sound
You have an HDMI connection on a Thinkpad T20???
Per definition, HDMI is supposed to send video and audio data from the TV to the PC -so, yes, it should work.
I say "should", because I tried to hook up my PC that way and I went back to a VGA connection (and sent the sound to an old stereo), because the resolution was awful.
I rather think that the audio cable is the culprit here - if the connectors are not fitting perfectly, they can create a lot of distortion.
Also check your audio settings on the PC (updated driver, settings not on maximum volume, etc.)
If you want to try HDMI, there is no need to get the ultra expensive "Monster" cable. Look here for an example.
Feb 24, 2009 | IBM ThinkPad T20 2647 Notebook
Seems to be no power to speakers.
Disconnect green speaker jack from computer and see if you get a green power light on speakers. If the speakers indicate they have power, your sound card or circuit is shorting out the speakers. If you still have no power to the speakers when disconnected from computer, then no green light means no power to speakers. Either you’re A.C. adaptor is bad or the speakers are shorted out. You have 2 options:
1) Replace A.C. adaptor.
2) Replace speakers.
If you buy new speakers, make sure that they have their own power source (A.C. adaptor).
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell A215 Computer Speakers
Only one of my speakers work
Dognayr15
Happy Holidays
well, if you put the green cable on the green connector on your sound card, you,ll be fine, and see if work, fine, depending on your configuration speakers, 5.1 or 2 way, you can test if the sound go on the 2 speakers.you also check if something is bad with the other speakers
Dec 26, 2007 | Acer 90.00012.30B Computer Speakers
Open Questions:
See all Creative Labs GigaWorks T20 Computer Speakers Questions
Creative Labs GigaWorks  T20 Computer Speakers Logo
206 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
