Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Power on and off
I have a Mits WS-65809. When I turn it on it powers right back off. Any ideas? Manuals or schematics?
  • Mitsubishi Master
  • 8,617 Answers
You would need to trouble shoot the standy voltages and see whats happening with them. I would suggest getting a service manual from the following link as they will email it to you quickly after purchase and they will provide free tech support to help you diagnose and repair your set. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 27, 2008
Mits WS-65857 no HD after repair
WELL YOUR LIQUID SPILL MAY HAVE BURNT FOIL PATHS OR EATEN UP SOME OTHER SOLDER JOINTS. A CLOSER INSPECTION ON THE AREA INVOLVED SHOULD SOLVE YOUR PROBLEMS.
Dec 27, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Turns of after being watched for several hours.
Do you have the tools required to solder electronics? Do you know how to solder electronics? Have you been trained in CRT safty ? Do you know about High Voltage safty? Is the tv Model number WS-65809? Do you know how to perform static geometry adjustement on a WS65809 if needed? Do you know how to perform static convergence alignment on a WS-65809? Do you know how to perform fine convergence adjustement to a WS-65809?
IF
The answer is :yes yes yes yes yes yes yes yes
AND
You can retreive an error code of 23 or 24 right after the tv shuts
itself off .
THEN
There is a 95% chance that I could tell you what to solder , no parts need to be replaced in your television and you would not have to pay someone to repair it.
Oct 04, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mits ws-65809 Won't turn on Blinking 2 2
2-2 is a error code that means short protection.
Usually in this set it means one of the fuses that protects the convergence circuit is shorted because of a bad convergence Ic.
I HAVE PHOTOS OF THE FUSES-- and THE PROTECTION RESISTORS- and I also have step by step from start to finish instructions for this repair in this set.
If you want the instructions and photos give me a vote here and I will be happy to email them to you and answer any questions you have. I have done hundreds of Mitsubishi sets with this problem---I just got home from doing one a few miles away from where I live.
REGARDS, SD TECH
Sep 17, 2009 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi ws-65809 when i turn it on it shuts down after 2 seconds, i held the input and menu buttons in and it gave me cod 2-3 was wondering what could be the problem, and if it is an easy fix...
Error code 23 means "Loss of Horizontal Deflection" that means horizontal section of TV is not working. Cause can be horizontal out transistor is short or not getting +B volts from power supply.
If you understand schematic, I can email you complete repair manual of Mitsubishi WS-65809 that will help you to diagnose problem by measuring volts and checking parts.
Thanks.
Sep 15, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Wont power on
did you check the two 5 amp picos that normally blow when the Ics fail? They are F9ao4 and F9a05
May 25, 2009 | Mitsubishi WS-65809 65" Rear Projection...
My mitsubishi ws-65809 will not power up.
Mine is doing the same thing. I just talked to the repair guy. It is a power supply problem. Try unplugging it for 5 minutes and turning it back on. Also if you were having problem with any picture issues it is the convergance, and that requires chip replacement. They are estimating $350.00 to replace the power supply.
Jan 02, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Flashing power light no picture
We would need to know the model number. you have indicated that it is ws-65809 but i don think this is your model because what you are describing is a bad dm module and the ws-65809 doesn't have one in it. Let me know and I can help your further!
Tim Nolan
Sep 21, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65809 turns off right away
check 2 5amp chem fuses. in middle of tv. yellow or orange in color . if bad replace the 2 stk convergence ics and fuses.
Nov 06, 2006 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
