I have a Konica Minolta 5340DL when a label it leaves a black mark on thne left side !
    President:
  • 4,070 Answers
HI! This problem is caused by a faulty drum. Replace it and you'll be good. Hope this helps and thank you for using FixYa!
Posted on Oct 02, 2010
What is the konica minolta black imaging unit ?
its the image unit below the black toner lower right. the image units go from left to right yellow magenta cyan and black.
May 09, 2014 | Konica Minolta bizhub C250 All-In-One...
How do I print labels on the bizhub 222
Be sure to load label sheets so that the side to be printed on faces down and a maximum of 50 label sheets can be loaded into the bypass tray.
USER MANUAL page 2-64
http://kmbs.konicaminolta.us/productsattachments/manuals/bizhub362SeriesCopyOperationUserManual.pdf
Jan 06, 2011 | Konica Minolta Bizhub 222 Black and White...
Image Transfer Belt Installation for Konica Minolta Bizhub C351
Transfer belt on this model is removed via left and right side of the machine two screws on the right side remove then the belt is pulled from the left side
Jun 23, 2010 | Minolta C350 Printer
Our 2300DL is leaving streaks when printing
Out of one or more toners. If you have removed and replaced a cartridge in error the % remaining is reset to 100%. Try to determine which color is missing in your print out (usually black), and then follow menu instructions to replace that cartridge. The ends are color coded so be sure you change the correct one. This will insure the remaining cartridges % remaining is correct.
Jan 13, 2010 | Konica Minolta magicolor 2300DL Laser...
Toner problems with Konica Minolta 2450
very annoying message i agree - most likely caused by toner dust.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Jan 12, 2010 | Konica Minolta Magicolor 2450 Printer
Piece of Paper stuck inside
Sounds like it could be a bit of a label stuck on the transfer belt. Open right side cover and undo the 2 screws located about 2 inches below the fuser, then open left side cover and remove the waste toner bottle and then slide out the transfer belt.
Remove paper and wipe over the belt with a soft damp cloth. If it is a label you will need to use an alcohol cleaner to remove the sticky residue (isopropyl should do the trick)
Good luck
Mar 19, 2009 | Konica Minolta bizhub C450P Laser Printer
Konica bizhub 250
on the left hand side of the platen glass there is a **** glass just clean that with alcohol or wet rag.
HH
Feb 14, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
26 people viewed this question
k24674
