Question about Vanguard International Blue Flame - Large Open Flame Mid-Size Heater
My heat resistant glass panel broke. I need measurements.
  • Vanguard Master
  • 2,557 Answers
No you need make model serial number then look on line at national energy for the parts, the numbers make etc are on the heater
Posted on Oct 03, 2010
  • Diane Arno Oct 03, 2010
    I have all that info. National energy does not list parts????
  • Paul Carew Oct 04, 2010
    I would phone them they are very helpfull , if they cannot supply the part they will know who does Have used them many times
Where can I get a heat resistance double sided tape to affix the external glass of the oven to the SS frame on my slide in GE stove .
Most of the time that GE attaches any type glass to hot metal these days they use silicone seal. It is uses to attach glass cooktops into the metal frame of the cooktop. Get a tube of GE clear silicone seal and glue the glass around the complete edge getting a good seal and contact at the glass edge and metal panel. Let it dry 24 hrs before reassemble. The silicone seal turns to rubber when dry and is quite heat resistant. It won't stand up to direct flame but should hold your glass well.
Apr 27, 2015 | GE Ovens
Tip
MICROWAVE POWER TEST Hi Everyone, In this tip I will show you how to easily test...
Hi Everyone,
In this tip I will show you how to easily test your Microwaves power. If it is sufficient, or if it is not heating effectively anymore.
Non heating Microwaves are a common issue, and the most likely component that is faulty is the Magnetron - These days Magnetron's are quite expensive (usually about 50% the price of a new Entry Level Microwave). Low heating could mean a Magnetron becoming faulty (unlikely, as a Magnetron either works, or it doesn't work)
Tools required: A Normal Glass (Heat-resistant, in other words Microwave friendly), Water (Room Temperature) , a Centigrade Thermometer (Can get this at any Pharmacy)
Procedure:
1) Fill a glass with approx. 125 ml water. Use water at room temperature (from the tap), avoid using refrigerated water as this will work against the test we are doing.
2) Measure the initial temperature of the water with the thermometer (It should be between approx. 10 & 20 degrees).
3) Place the glass with the water about 2 cm away from the center of the Microwave Oven plate.
4) Heat the water at full power (The highest setting possible on your Microwave) for 70 seconds.
5) Stir the water (For 5 - 8 sec).
6) Measure the final water temperature with a thermometer.
7) If the increase is 45 degrees or more, then your microwave is heating sufficiently, if not it could mean replacing the Magnetron, or purchasing a new Microwave.
I hope this guide as helped you. If it has, please rate it accordingly.
on Apr 23, 2011 | Microwave Ovens
Tip
Whirlpool Dryer Various Test Procedures - Part 2
TEST #4 Heater
This test is performed when either of the following situations occur: Dryer does not heat Heat will not shut off
This test checks the components making up the heating circuit. The following items are part of this system:
Harness/connection, Heater relay, Thermal cut-off, Thermal fuse, High limit thermostat, Gas burner assembly,
Centrifugal switch, Exhaust thermistor, Machine control electronics, Gas supply. Dryer does not heat:
1. Unplug dryer or disconnect power.
2. Remove the back panel to access the thermal components.
3. Perform TEST #4b. If the thermal fuse is OK, go to step 4.
4. Perform TEST #4c. If the thermal cut-off is OK, go to step 5.
5. Locate the high limit thermostat. Measure the continuity through it by connecting the meter probes on the
red wire and blue wire terminals. If there is an open circuit, replace the high limit thermostat and thermal cutoff.
Otherwise, go to step 6.
6. Perform TEST #4d. If this is OK, replace the machine control electronics.
Heat will not shut off:
2. Access the machine control electronics, remove the P14 connector, then measure the resistance between P14-3 (red-white wire) and P14-6 (red-white wire) at the connector. If 5–15 k ohms are measured, replace the machine control electronics. If the resistance is greater than 20 k ohms, replace the exhaust thermistor.
TEST #4a Exhaust Thermistor
The machine control electronics monitors the exhaust temperature using the exhaust thermistor, and cycles the heater relay on and off to maintain the desired temperature. Begin with an empty dryer and a clean lint screen.
1. Plug in dryer or reconnect power.
2. Start the Timed Dry cycle.
3. If after 60 seconds, F-22 or F-23 flashes in the display and the dryer shuts off, the thermistor or wire harness is either open or shorted. Unplug dryer or disconnect power. Check wire connections at the machine control electronics and thermistor. If wire connections are OK, check exhaust thermistor resistance per step 5.
4. If F-22 or F-23 does not flash in the display, the connections to the thermistor are good. Therefore, check the exhaust temperature value at any or all of the temperature levels in question, using the Timed Dry cycle, and the following process: Hold a glass bulb thermometer capable of reading from 90° to 180°F (32° to 82°C)
in the center of the exhaust outlet. The correct exhaust temperatures are as follows:
TEMP
SETTING HEAT TURNS
OFF* HEAT TURNS
ON High 155° ± 5°F
(68°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Medium 140° ± 5°F
(60°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Low 125° ± 5°F
(52°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature Extra Low 105° ± 5°F
(41°± 3°C) 10–15°F
(6–8°C)
below the
heat turn off
temperature The measured overshoot using the glass
bulb thermometer in the exhaust outlet can
be 30°F (17°C) higher.
5. If the exhaust temperature is not within specified limits, or you have come here from step 3, remove the P14 connector, then measure the resistance between P14-3 (red-white wire) and P14-6 (redwhite wire) at the connector. If the resistance is OK, check P14-3 and P14-6 to machine ground. If resistance is greater than 0 (zero), replace wiring harness. NOTE: All thermistor resistance measurements must be made while dryer is
disconnected from power. The following table gives temperatures and ranges for the associated thermistor resistance values.
Temp
F C
Res
kΩ
Temp
F C
Res
kΩ
50° (10°) 19.0 -22.0 80° (27°) 8.5-10.5 60° (16°) 14.8-16.8 90° (32°) 6.8-8.8 70° (21°) 11.5-13.5 100° (38°) 5.0-7.0 If the thermistor resistance does not agree with table, replace the exhaust thermistor. If the thermistor resistance checks agree with the measurements in the table, replace the machine control electronics.
TEST #4b Thermal Fuse
The thermal fuse is wired in series with the dryer drive motor.
2. Access the thermal fuse by first removing the back panel.
3. Using an ohmmeter, check the continuity across the thermal fuse. If the ohmmeter indicates an open circuit,
replace the failed thermal fuse.
TEST #4c Thermal Cut-Off
If the dryer does not produce heat, check the status of the thermal cut-off.
2. Access the thermal cut-off by first removing the back panel. .
3. Using an ohmmeter, check the continuity across the thermal cut-off. If the ohmmeter indicates an open circuit,
replace the failed thermal cut-off and high limit thermostat. In addition, check for blocked or improper exhaust
system.
TEST #4d Gas Valve
2. Access the gas valve by removing the front panel and drum assembly.
3. Use an ohmmeter to determine if a gas valve coil has failed. Remove harness plugs. Measure resistance across terminals.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Need either Manual or Dimensions for the inner glass on My Necht BD-224A Oven?
please get a service tech, no need to damage the unit
& it will only cost you more in the end, its a special heat resistant glass
Feb 11, 2015 | Ovens
How do I find lower oven outer tempered glass part # and where to buy mod #C70-60122.
What brand? Look up manufacturer for parts outlets or measure glass and get a glazier to cut a new one. You have to yell him it has to be heat resistant for an oven.
Dec 02, 2014 | Ovens
Best way to hold up broken drivers side window
common problem and easy to change . aftermarket regulators are around 100$. but if need be remove door panel and use a measuring tape and measure from the bottom inside door upto the bottom of glass when up. cut a 1x3 piece of wood to length and slide it in as a temp solution
Mar 16, 2014 | 2000 Oldsmobile Alero
Glass broke in Canon Copier PC921 need replacement
Just buy an ordinary glass from aluminum and glass supply shop. Just measure the thickness and with so they can cut the right size. We did try it to our machine and no bad effect on print pouts. Just give it a try.
Apr 02, 2013 | Canon Office Equipment & Supplies
Oven Door Glass -Seal has disintegrated. Is there a glue to re-affix the interior glass panel or do I need a new door?
You can usually refix the glass panel back into the oven door with the correct adhesive. It needs to be the correct heat resistant adhesive.Try http://ovendoorglue.com
Jan 13, 2012 | Cars & Trucks
I have a sector urban oversize watch 3H case diameter 4.8mm with a broken watch glass crystal.I would like you to inform me of the replacement glass diameter and thickness i should choose to fit the...
I cant inform about the exact size of the watch glass by the model or number of the case. For that you need to use micrometer to measure the thickness and diameter of glass. Most sommon thickness is 1mm. If the glass is broke, measure the thickness of any broken leftover and then the diameter by puting the calliper arms into watches groove for glass.
Aug 26, 2010 | Watches
Zanussi oven ZBF360 X, Door coming off
You Can buy Heat Resistant Glue at Espares.co.uk
Worked for me!
Aug 23, 2008 | Zanussi ZBF360X Electric Single Oven
Vanguard International Blue Flame - Large Open Flame Mid-Size Heater Logo
53 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
