Rank: Guru
Rating: 91%, 827 votes
Yes, you need to adjust the knob that controls the amount of maximum humidity the unit will saturate the air with. The unit may be pointed in a direction that isolates the ambient air surrounding it incorrectly. Move it so the air points to the center of the room with no obstacles in its way of airflow.
If it is in a location that aerates an entire room with no obstacles in its way and the air saturation control is set to its highest setting, then when the unit stops it is because the humidity in the area immediately surrounding the unit is saturated but areas distant from the device are not.
If you have a ceiling fan in the room, set it for upflow and then a low setting. This will help keep the air in the room circulating. Otherwise a small fan pointed at the ceiling somewhere will accomplish the same thing eventually. This mixing from a ceiling fan or small fan takes some time to get the air in the room at even saturation.
If you have tried all this, please comment back with the Maker and model as well as serial number if you can find it. Please include the date of purchase as well and if you purchased this wit a credit card as it may double your warranty period
Then, I'll be glad to assist you further. OK?
Regards,
Worldvet
Comments:
May 28, 2008
- Hello,
Based on the myriad of responses you have heard and your now realizing your machine is not emitting any humidity because the wheels will not turn, you have two things plaguing your situation. Mineral build up on the bushing the wheels are mounted on and/or plastic gear teeth that have worn down and have caused the drive wheels to jam.
You can empty the unit of water and see if you can manage to turn the wheels yourself to break the jam, while being very careful of your hands and wearing gloves. Protect your hands from being pinched accidentally.
If the rods the wheels are mounted on have a lot of white crust on them you may have a frozen wheel due to the corrosion and they need to have the corrosion removed and be lubricated with the proper lubricant.
If you can move the wheels yourself and they appear unjammed you will want to lubricate the section where the rods pass through the wheels. The lubricant to use is rather specific to your machine and you should call the manufacturer for advice on which lubricant to use and should the teeth on the plastic wheels have worn down to the point they jam easy, you will need to seek professional service from a company who has the facility to remove the corrosion, replace any wheels that need it and lubricate the wheels properly.
Sorry, to be the bearer of bad news and sorry my first offer was off base and misunderstood. I would return it to the place of purchase and explain your problem. If they give you a stonewall to climb I would ask for a manager or supervisor. Then, you'll have to decide if the cost of repair outweighs the cost of replacement.
Thank you for using Fix Ya and I hope this information is more clear.
Regards,
Worldvet
May 28, 2008
- Hello,
Oh and by the way, there may simply be a set screw or bolt head that holds the drive wheel to the main motor drive rod. If you see one, turn the drive rod until you see a flat spot, position the main drive wheel over this and screw it won with a proper screwdriver to hex head which ever it is, if you don't know and this is the case describe it's look for me and I'll advise you.
Regards,
Worldvet
